balance shafts
I am putting in a water pump (had the t.belt done but not the w. pump a couple of months ago) and I got it to tdc and marked the cam and crank gears but not the bal. shaft gears and I seem to have moved them a little (didn't realize they moved so easily). I was told its not that big a deal and that I can spin them a little and they will rest in a "heaviest end down" manner . Is this true or is there something else I need to do or are they ok the way they are ?
Thanks , cj44
Old 10-24-2004, 09:34 PM
gravity will pull them in to the wrong position. Follow Clark's garage notes, great info
http://www.clarks-garage.com/
the article on the balance belt is here.
http://www.clarks-garage.com/shop-manual/eng-06.htm
Rick
99 996C4
06 525XI
87 944S - Sold
77 924 - Sold
Old 10-25-2004, 03:23 AM
Rmills944's Avatar
Send a message via AIM to Rmills944 Send a message via Yahoo to Rmills944
Just don't put them on 180 degrees out. THey will vibrate like you've never seen when you hit 3000RPM and up.
Ryan
'84 944 moneysucker edition (SFR, Corbeaus, etc.)
'02 Jetta TDI 280Lb/Ft 145Hp @ wheels. RC2 PP357's
Old 10-25-2004, 07:15 AM
BALANCE SHAFT
RB101 THANKS THAT WAS GREAT REFERANCE. I THINK IT TELLS ME EVERYTHING I NEED TO KNOW.
cj44
Old 10-25-2004, 01:10 PM
TSNAPCRACKLEPOP's Avatar
be sure to keep the balance belt tense while putting it on or you may be 1 tooth off, ask me how i know. it will vibrate if off 1 tooth. don't put all the covers on till you are sure.
dr t
chance favors the prepared mind
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 10-25-2004, 01:19 PM
tsnapcracklepop, thanks I will keep that in mind.
Old 10-25-2004, 01:36 PM
