Stan944's Avatar
Question How to mount the throwout bearing (clutch job)?
I need to know the order of placing the shims and rings for the clutch throwout bearing. Neither Hayness, Clark’s Garage, nor FSM address this issue. When I removed the old one, I found FEWER rings than came in my kit from Pelican, i.e. 1 shim ring vs. three.
Here is the order on the OLD clutch, listed from the rear of the car, towards the front:
throwout bearing
toothed ring
teeth of the pressure plate
shim-like ring
thick ring
snap ring
My kit came with 3 shim rings, not just one, hence my confusion.
To mate the components nicely, I would put them in the following order:
Throwout bearing
1st shim ring
Toothed ring (with the teeth pointing to the front of the car)
2nd shim ring
3rd shim ring
thick ring
snap ring
I would appreciate comments on this issue.
Does the presence of the rings affect the point (in terms of depressing the clutch pedal) when the clutch disingages?
1983 red Porsche 944
Old 10-24-2004, 09:30 AM
Put the shim rings all together. Start with 3, and, if you can't install the snap ring, remove one, then try again.
The purpose of the shim rings is to remove play between the TO bearing and the pressure plate.
gb
Good luck, George Beuselinck
Old 10-24-2004, 06:03 PM
