dc914guy's Avatar
Send a message via AIM to dc914guy
Clutches
Hello all~
I am curious what kind of clutch you guys recommend? Vertex has the 'Power Friction' for $160! Does anyone have any experience, or should I stop being cheap and just buy the Sachs kit?
Thanks,
~Eric
Eric Devansky
986s - Radio Flyer
20% of a 951 parts car remains
Old 10-25-2004, 11:57 AM
Rmills944's Avatar
Send a message via AIM to Rmills944 Send a message via Yahoo to Rmills944
I have a turbo clutch in mine - in fact, the stock turbo clutch is the SAME as the centerforce for the N/A except for the weights. Just don't get a rubber-centered unit as they can cause a lot of problems.
Ryan
'84 944 moneysucker edition (SFR, Corbeaus, etc.)
'02 Jetta TDI 280Lb/Ft 145Hp @ wheels. RC2 PP357's
Old 10-25-2004, 12:58 PM
dlknight's Avatar
Hey,
I ordered a "stock" sachs clutch kit recently for my 944S and it has springs rather than the troublesome rubber centre that the original clutches had.
Cheers
Dave K.
1990 Panther Black 944 Turbo
Old 10-25-2004, 01:05 PM
lousailor's Avatar
Send a message via AIM to lousailor Send a message via Yahoo to lousailor
Most of the aftermarket Sachs kits use the spring centers, but even the OE rubber center clutch disks will last a good long time (most made it to 15 years at least). I would check with someone who's tried a different maker's set. OEM works well but only if adjusted rightl, and I've also discovered that machining the flywheel can lead to slippage at higher horsepower.
Louie
'85 (Early) 944 - Beater
'87 924S - Crunch/Rebuild
'76 924 - Long Gone
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
Old 10-25-2004, 04:12 PM
Mein Gott!
Panzer909's Avatar
The rubber-centered clutches are very underrated and get a bad rap. If you're tracking the car and/or riding your clutch like a ricer kid, that's one thing. But if you're just doing normal driving I'd recommend the rubber centered one over springed.
Why? Well, I've had both, and the springed-centered clutch was actually more noisier with more "chatter". This was annoying. I know a former Head Technician at a well-known local dealership that swears by the same thing. I've put about 70,000 miles on mine with no end in sight.
Clutches are like anything else; it you treat it right it will last a LONG time.
Johnny
1987 944S
1984 944 (R.I.P.)
1972 Triumph TR6 - 100% trouble free between breakdowns
2003 BMW 325xi
Old 10-25-2004, 05:31 PM
Panzer, you may be right, but the issue is the rubber center's tendancy to deteriorate. The degredation of the rubber, from what I understand, is more time related than abuse related. If you buy the rubber centered unit that was recently produced, it should be fine, but what if you are shipped a NOS unit that was produced in 1896? I went with the spring clutch because I'm a whimp and would be sorry if in a year or 2 the rubber center went out and I was out the parts $ and all that labor time.
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work.
Malo periculosam, libertatem quam quietam servitutem.
Old 10-25-2004, 06:00 PM
Mein Gott!
Panzer909's Avatar
Not to worry, my friend - I can assure you that there were no NOS clutches produced in 1896. You should be fine.
Johnny
1987 944S
1984 944 (R.I.P.)
2003 BMW 325xi
Old 10-26-2004, 11:37 AM
lousailor's Avatar
Hmmm . . . he may have meant 1986
Louie
'76 924 - Long Gone
- Mario Andretti
Old 10-26-2004, 12:01 PM
Zero10's Avatar
Send a message via ICQ to Zero10
LOL, I won't even touch that one....
I believe in 1896, they still got rubber from rubber trees, and I don't think they made clutches with rubber centers, at least not for 944's =)
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 10-26-2004, 08:01 PM
Come on guys, I'm a victim of the Pennsylvania public school system, cut me some slack. I did indeed mean 1986.
Old 10-27-2004, 03:30 AM
lousailor's Avatar
Yeah Dyslexia is not ynnuf!!
Louie
'76 924 - Long Gone
- Mario Andretti
Old 10-27-2004, 08:55 AM
Zero10's Avatar
Sorry, I couldn't resist...
Buy my parts!
Old 10-27-2004, 12:37 PM
Still though, that actually was my reasoning (misrepresented as it was). I was concerned of the time induced deterioration of the rubber center, and no way to determine the manufacturing date of the clutch. Is that a foolish concern, or is it valid?
Old 10-27-2004, 05:47 PM
Mein Gott!
Panzer909's Avatar
It is a valid point.
Like anything else made of rubber, time will break it down. Especially if it is not used, dry rot can and will happen. However, what I'm saying is that, if you're not going to pound the crap out of it, a rubber-centered clutch is fine. It will still last for a long time and will be quieter to boot. I'm speaking from experience.
Johnny
1987 944S
1984 944 (R.I.P.)
2003 BMW 325xi
Old 10-27-2004, 07:06 PM
Eric 951's Avatar
Yes--he knows of what he speaks. he is running a rubber-center clutch and it is smooth as butter.
BTW--there is a guy on Rennlist--Wade who has 300K on his 944NA with the ORIGINAL clutch--I saw the car and it looks like a 50K mile car.
All that being said--I have a Sachs spring on mine
Eric
83 911SC
76 CB 750 Cafe/78 CB 750F/83 VF750F/75 CB750F
Old 10-28-2004, 04:44 AM
Rmills944's Avatar
I just don't trust them because the previous owner didn't drive my car much (9 years old and 23,000 miles when bought). That didn't seem to help the clutch seeing as it went out with 70,000 on the car and took the transmission with it. I'd rather not have another bill for $3500 for a tranny and clutch job. I figure the car is loud anyways (especially with the SFR system) and I can't hear it anyways, so I'm playing it safe and using a turbo clutch. Even if I was hard on the clutch doing track events on weekends, I'd expect mine to last at least 150,000 more miles!
Ryan
Old 10-28-2004, 07:26 AM
lousailor's Avatar
Rmills,
Did you have to swap out the bell housing or change the flywheel to use the turbo clutch?
Louie
'76 924 - Long Gone
- Mario Andretti
Old 10-28-2004, 08:47 AM
Rmills944's Avatar
fly wheel - my shop did the work on the car back then
Ryan
Old 10-28-2004, 08:52 AM
Send a message via AIM to bluebullet
I used a sachs spring kit. Had no problems so far and its a joy to heel-toe downshift. I broke the clutch in for about 600 miles of stop and go driving and most of this cars miles is highway miles. so the clutch hardly gets used. The OE clutch had 75k miles on it and lasted 20 years
1985 944 / 2007 335i / 1987 325is / 1985 535i / 1999 528iT / 2006 X5
Old 10-28-2004, 09:37 AM
Ornery Bastard
Yes the rubber center is quieter. That's the _only_ recommendation I've ever gotten in favor of it from any mechanic.
Still, the extra noise from the spring center clutch is all but imperceptible. I went from a rubber center to a spring center and there was not so much an increase in noise as a change in the character of the noise.
Anyone who has a problem with the extra noise of the spring-center clutch should really re-consider their rationale for having a sports car. I mean, the extra noise doesn't even necessitate bumping up the volume of the stereo by one unit. I've had tires make far more noise.
Aaron
Shifting is an art. Learn it, love it, live it.
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 10-29-2004, 06:32 PM
