Sun roof question
My 85 N/A 944 has no sun roof in it, as in the P.O. took it out and did not replace it. I have a couple that I can get, but did Porsche sell the 944 with a manual sun roof or are they all electric. Also, does a 924 sun roof fit in a 85 944?
2011 Chevy Silverado (The Hauler)
1984 911 Carrera summer daily driver
Old 11-02-2004, 10:19 AM
Rmills944's Avatar
Send a message via AIM to Rmills944 Send a message via Yahoo to Rmills944
Do you mean you're missing the manel, or he welded a steel panel in place of it, or is there a hole in the roof all the time, what?
Also, if you had a sunroof, you'd have the lifting arms at the back of the sunroof hole. They did offer a manual roof, and a lot of people switch the power roof over to a manual roof simply because the auto roof is real hard to keep adjusted and working.
Ryan
'84 944 moneysucker edition (SFR, Corbeaus, etc.)
'02 Jetta TDI 280Lb/Ft 145Hp @ wheels. RC2 PP357's
Old 11-02-2004, 11:17 AM
The PO pulled the sunroof out and replaced it with nothing. I guess this has a manual sunroof, since I see no arms. The two roofs I can get are electric and 924's. I guess I'll just try it!
Old 11-02-2004, 11:47 AM
Rmills944's Avatar
yeah - I'm not sure about the fit. The manual arms would have a little retracting mechanism and you'd see something like a black box with 2 levers that can retract into the panel behind the sunroof. The arms would push forward and up when the sunroof is in place. There is plastic trim (a box) around the arms, so they won't just be hanging out there. The manual roof just pretty much just clips onto a metal lip up there.
Ryan
Old 11-02-2004, 11:54 AM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson
It could be that it's a saratoga and he put the solid top in... ? I can take pics of what mine looks like with the solid roof in and you can compare if you want.
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 11-02-2004, 01:33 PM
The picture would be great. I do remember him saying something about a glass (saratoga) top.
Old 11-02-2004, 05:30 PM
tifosiman's Avatar
So, if I missed the answer to this question, I apologize........
Is there a gaping hole in your car where the sunroof panel used to be, so that there is rain/wind/birdpoop falling into your interior?
Or do you mean that the previous owner removed the stock sunroof panel and replaced it with something else?
If you need the solid, stock sunroof panel, those are readily available at most dismantlers.
1985.5 944 Club Sport
My P-caronline Profile
"A good time to keep your mouth shut is when you're in deep water. "--
Sidney Goff
Old 11-03-2004, 09:22 AM
I'm off the hook.....
And yes, I believe any manual roof will fit any manual car. Even the 924's.
Your PO probably sold the Saratoga roof (clear panel) when he found out it was worth as much as the entire car.
No, I don't sing. Based there for too long.
Old 11-03-2004, 01:48 PM
