-   -   trouble aligning the motor... need help. (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/190905-trouble-aligning-motor-need-help.html)
EricMcIntire 11-05-2004 11:37 AM
hey I'm having trouble getting the motor to slide onto the drive shaft, I aligned the clutch and everything... any advice?
Nigel Haslock 11-05-2004 01:48 PM
Put the tranny in gear, apply hand brake and get someone to slowly turn the rear passenger side wheel as you slide the engine onto the end of the drive shaft.
The CAT will align the clutch plate with the flywheel and pilot bearing but is no guarantee that the splines are in the same orientation as the drive shaft.
Spinning the driveshaft is easier than spinning the crankshaft to get them to line up.
Nigel
