924s specs
Does anyone know actual 1988 924S specs like 0-60mph, horsepower/torque, compression ratio, etc? They have eluded me so far.
The Porsche 924S has the 944 drive train in 924 body, lighter, more aerodynamic and faster than the regular 944. The 88 models had a "sport" option available.
In North America, the engine was identical to the 944, a 2.5l 147HP unit that should have been in the 924 from the beginning. Straight-line speed was actually faster than the 944 due to a lower fifth gear and reduced drag. Contemporary magazine reports rated it similar to the 944S (188HP) of the same year. Initial 924S' in the rest-of-the-world (RoW) received a 150HP (DIN) motor, noticeably weaker than the 163HP DIN 944 motor. In 1988, sanity prevailed and the better motor appeared in the 924S, and the US cars were uprated to 160 HP. This makes 1988 models slightly more preferable to the other years. hope this helps Ade
----------------------------------------------------------- The fear of God is the begining of wisdom <>< NotJustPorsche Subscribe: notjustporsche-subscribe@yahoogroups.com |
0-60 ? which gear? I got to 65 in second,, about 5 seconds guessing.. what a rush.
1988 924s mars red coastal cruzer |
whats your location , burnout?
when i tried it it was around 6 something, but that isnt with reving it and dropping the clutch like in a drag. i didnt want to be too hard on the clutch.
Special Edition 924S 1988 <- SOLD! Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker. |
Did you guys time those runs? I'm looking at the factory technical manuals and they are saying in the 8 second range. I've heard the factory is pretty conserative, but 2 seconds is quite a bit.
Although...I've got on it pretty hard up through the end of third, and it sure doesn't feel like 8.3 seconds to 60.
I turn away with fear and horror from this lamentable sore of continuous functions without derivatives. --Charles Hermite Fakelife.com Nothing to do with archery anymore. Porsche/BMW/Ferrari/Honda videos |
Writer/Teacher
The 924S was virtually identical to the early (1982-1985.5) 944 in every way except the body panels.
0-60 - 7.8 sec top speed - 137 mph I believe the gearing in the 924S is the exact same (except 5th?) as the 944NA, so in 4th gear 2000 would be about 35mph, 3000 would be 60ish, and 4000 would be about 85.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. |
