-   -   Problem...no spark...need diagnosing help (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/192193-problem-no-spark-need-diagnosing-help.html)
Makenzie71 11-17-2004 06:30 PM
Originally posted by carsontc
curious...do you know how old is the DME / Fuel Pump relay is ?
the distributor cap ?
the rotor ?
the spark plug wires ?
the fuel filter ?
if the answer to any of these is more than 5 years...you are taking chances
most worry about oil changes, air filter, spark plugs and with hope, timing belts
these other bits can and will bite you if ignored
The relay, though I think it's an original Porsche part, is spotless. I checked every component in there out and found nothing wrong with it what so ever. Everything else I believe needs to be replaced...but their wear would lead to a slow decline in performance, eventully preventing the car from running. Not a sudden stop as what happened with mine.
carsontc 11-17-2004 07:38 PM
so you believe "everything needs to be replaced"...probably close to 20 years old..."but their wear would lead to a slow decline in performance, eventually preventing the car from running. Not a sudden stop as what happened with mine"
I have changed my 'said' parts and can soak the balls off my engine compartment...but what do I know?
Makenzie71 11-17-2004 07:42 PM
That post really didn't make a lot of sense to me...but umm...not, not original stuff. The wires and plugs are not original...fairly recent with the wires, the plugs aren't worn, just noticeably old.
livewirevoodoo 11-17-2004 07:59 PM
WFIW... I had a similar condition Monday. Stopped at work for 15 mins to hand in an OT slip. Had been driving all morning, no prob. Try to start her up and she won't turn over. Called AAA for a jump, nothing doin. Had AAA tow her to my mechanic (best $70 a year i've spent on a car). 2 hrs later it's back up n running. He said it was the crankcase sensor. Dunno if thats been mentioned before under another euphemism.
Anyways.. Best of luck Makenzie. Hopefully its nothing too $erious. I am learnin alot about troubleshooting from this thread tho.
Makenzie71 11-17-2004 08:36 PM
Crankcase sensor? I'll have to do some looking on that. You happen to be willing to share your mechanic's name and contact info, would you?
livewirevoodoo 11-17-2004 08:42 PM
Sure...
Burnside Automotive
Tony Matthews
860-289-4590
360 Burnside Ave.
East Hartford CT
my future (hopefully) brother in law. he's owned a 944 or two before, so he knows them well. he had a black on black 928 on the lift when i went to pick my car up. i was hatin, lol.. it was gorgeous.
porsche944speed 11-18-2004 06:56 PM
drop a lit match down the gas tank that will take care of all ur problems you wont even need to spend 30 for a dme relay just a phone call the to the fire dept
Makenzie71 11-19-2004 08:18 PM
Unplugged one injector and the car hit, didn't start but you can definitely tell it hit. HAd no time, will look more into it monday. How exactly do I test the FPR?
livewirevoodoo 11-19-2004 09:16 PM
Clarks Garage - Fuel Pressure Regulator
ae1969 11-20-2004 10:43 AM
If it runs on 3 plugs it is usually a good indicator that it is the FPR as I explained a page or 2 back.
I would not start throwing parts at it until you can confirm that the fuel pressure is out of spec. You need a fuel pressure guage. This can be attached at the end of the rail.
Makenzie71 11-26-2004 03:32 PM
starting to irritate me...but at least I know where the problem lies. The injectors aren't firing. Which means either no fuel pressure or FPR is broken. Haven't gotten into it enough to test yet...todat I got to really touch the car for the first time since she went down.
I know now:
Turn key, no hit.
Spray B12 into intake, hits until b12 is gone.
ae1969 11-26-2004 04:02 PM
I know now:
Turn key, no hit.
You haven't been reading............
Thats a bad MAC ............bad. :D
Did you check the voltage on the injectors.......... what did you get on both pins with the ignition ON
Makenzie71 11-26-2004 05:11 PM
