strath44's Avatar
Galvinised body panels
Hello all, I've picked up a set of replacement front wings for my '44. Just wondered how the best way to prep them for painting. If I use paint stripper will it remove the galvinisation from the panels?
1991 944 Turbo
2012 VW Passat
2008 Mini Cooper
Old 11-14-2004, 04:06 PM
AFJuvat's Avatar
NO, stripper will not remove the galvinized coating.
Sanding or grinding will
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 11-14-2004, 04:58 PM
strath44's Avatar
I think they started galvinising the 924's in 1981 or maybe it was 82 when the 944 came out always forget which.
1991 944 Turbo
2012 VW Passat
2008 Mini Cooper
Old 11-15-2004, 12:32 AM
speed's Avatar
make sure to use a zinc primer so it can adhere to the galvanize metal.
1985.1 944n/a
Old 11-15-2004, 05:31 AM
Zero10's Avatar
Send a message via ICQ to Zero10
All 944's were galvanized, and I think the later (81&82) 924's were as well.
The 911's started being galvanized in the mid-70's (75??), I think it was 75, since none of the 914's were galvanized, and they were made until 74...
Anyhoo, just some irrelevant guesses =)
No stripper will remove the galvanization, however if you're really hard on it with a scraper, you can remove it! So, go easy with the scraper, I used only plastic/rubber scrapers to help keep it intact.
Por-15 makes a great surface prep spray for galvanized metal, and most of their paints are designed for galvanized metals.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 11-15-2004, 01:07 PM
strath44's Avatar
cool - reason i'm liking to here I can use paint stripper is that I get home to late from work to crack open the buds and go hammer and tongs with the belt sander/drill etc in our quite neighbourhood!
1991 944 Turbo
2012 VW Passat
2008 Mini Cooper
Old 11-15-2004, 02:00 PM
