-   -   944 haunted, window to another dimension? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/192564-944-haunted-window-another-dimension.html)
TSNAPCRACKLEPOP 11-16-2004 03:41 PM
i am driving down the road, minding my own beeswax. suddenly a chill goes down my spine!!! no, i feel a draft, and i look to my right, and the passenger window is lowering itself, all by itself. i hit both buttons, and it will not go up. will check fuses, but, is this a common gremlin.
thoughts appreciated.
dr tom
bryanthompson 11-16-2004 03:56 PM
mine doesn't go by itself, but it sometimes won't go up or down. flicking the switch really quick sometimes gets it going. I took the switch off the other day and cleaned the plugin and whatnot... not sure if it did any good. I drive alone 99% of the time, so I just leave that window alone and its fine :)
mambodave 11-16-2004 04:41 PM
Just for kicks , go rent the movie "Christine"
scheistermeiste 11-16-2004 05:18 PM
i had a car do that to me before. then after a while whenever my base would hit the windows would go down a little. then sometimes id be driving down the road and the alarm would start going off. ended up being a loose alarm connection.
livewirevoodoo 11-16-2004 06:12 PM
i had the same problem w/ passenger side window.
the window switch has 2 springs inside which, in addition to providing the 'tactile response' (firm click when pressed) also keep the electrical contacts in place so they don't make a connection unless pressed. If you take apart the window switch and adjust the tension on the springs (sounds like yours might be a little too compressed) that seemed to work for me.
Karl2bdc 11-17-2004 03:30 PM
I would guess it has something to do with that rear timing cover of scotts.
CJFusco 11-18-2004 08:18 AM
An exorcism is needed
a fellow Porschephile had a similar haunting in his 1990 BMW 5-series. Right after he bought the car, he allowed a valet to park it. Afterwards, the car was consumed by an overwhelming stench that would latch itself onto whoever entered. Relationships were ruined. A complete cleaning was unable to rid the car of the pesky spirits. Eventually he had to leave the keys in the car and hope that someone would steal it, because no dealership would take it back.
Clowd 11-18-2004 08:21 AM
That sounds familar... Jerry Seinfeld?
CJFusco 11-18-2004 09:36 AM
ding ding ding... we have a winner.
krahm 11-18-2004 09:27 PM
Jerry Seinfeld is working as a valet? Dude needs a new agent....
CJFusco 11-18-2004 10:14 PM
no, Jerry was actually the spectral B.O.
The valet was Ted Danson.
Zero10 11-18-2004 10:37 PM
That episode was great =)
I'm a big fan of that show, sucks that it was taken off the air, but I guess it had it's time.
CJFusco 11-19-2004 06:52 AM
'twas the last great sitcom
mambodave 11-19-2004 06:54 AM
its not off the air...you can watch it 6 times a day on satelite.
Was one of the best shows...
Loquat15 11-19-2004 10:21 AM
Could your knee be pushing against your window switches? a friend of mine kept doing that when he was in my 944, pretty funny stuff right there. Oh, my window switch on the driverside for the passenger window is fudged up, gotta push REALLY hard to make it work, sometimes that doesnt even do it.
Panzer909 11-19-2004 02:52 PM
I had passenger side window problems on my '84 a long while back. Turned out to be those two metal-looking tabs inside the switch. They were pressed too far in so they simply wouldn't make contact with the outside plastic part. Maybe yours are the opposite - the tabs are too far "out" and will activate if someone even looks at them wrong(?)
TSNAPCRACKLEPOP 11-22-2004 05:38 AM
do you mean that "tabs" is far out??? i think we all have quirks!! lol
