scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
Exclamation question on brake bleeding
if you replace all 4 calipers and in the process let the MC go dry do you have to bleed the MC too?
reason being is im using a vacuum pump and ive been bleeding the rear caliper forever and fluid still has a lot of bubbles with it coming threw the tube to the pumps resivuor.
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 11-16-2004, 08:56 PM
winter-hater club member
nynor's Avatar
i think you may be getting bubbles from all the other lines in the car. did you replace them one at a time and bleed the lines, or did you replace them all and then start bleeding?
"COOL PRIUS!" - Nobody Ever
Old 11-16-2004, 09:00 PM
Send a message via AIM to Makenzie71 Send a message via Yahoo to Makenzie71
if the m/c went completely dry, or even mostly, you need to treat it like a complete system install. Bleed the hell out of everything. It's probably not necessary but they are your brakes.
http://forums.pelicanparts.com/uploa...1093905626.jpg
the "baby" that comes first...
jm951's Avatar
It helps to inject some brake fluid into the mc before installing the resevoirs. Leave the lines off of the calipers and inject some fluid there from the mc end. Reconnect the lines to the calipers, then the mc. Refill the resevoirs, then bleed the system thoroughly. Worked for me every time.
86 951- again on the road, but needing some more TLC
82 931- again among the rolling
"If yer paint aint chipped, you aint passin nobody."
Old 11-16-2004, 09:03 PM
i replaced all 4 capilers then started bleeding. the brakes do work but they bite late.
Old 11-16-2004, 09:30 PM
seaboltman's Avatar
I did the same thing a little bit ago. Just keep at it. remember the order
Left rear
Right rear
Left front
Right front
Get another person out there to give you a hand. Have them step on the brake, then open the valve till nothing else comes out, close it, and then tell them to lift their foot. Keep doing that until No air comes out. If you keep going for a while and air is STILL comming out, do the other lines, then start back at the left rear again and go until no air comes out.
1987 944 - Wrecked turned parts car
1986 944 - Awesome Auto
Old 11-17-2004, 04:41 AM
Isn't it passenger rear, driver rear, pass front, driver front? From farthest to closest? (Left is always the driver's side to my thinking.)
P.S. Are you certain that the bubbles aren't coming from an imperfect seal of the hose on the bleeder valve with the vacuum pump?
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work.
Malo periculosam, libertatem quam quietam servitutem.
Old 11-17-2004, 06:00 AM
seaboltman's Avatar
ya passenger rear, driver rear... Furthers away to closes. Left being the passenger side if your looking at the car from infront.
Old 11-17-2004, 06:08 AM
well i bled the system for 2 hours straight last night.... i still saw bubbles, but hopefully it was just from a bad seal like taz said. i guess ill find out today!
Old 11-17-2004, 09:18 AM
TCMdocs944's Avatar
Speed bleeder screws make the whole deal a hell of a lot easier and are cheap.
Got those sheist?
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 11-17-2004, 10:01 AM
nope, i dont have those. but i was thinking that my pedal is out of adjustment. before i did this job the brakes would bite low to the floor, but i had a seized caliper and thought that was it.
but when they do bite they bite pretty hard... its just on the floor...
Old 11-17-2004, 11:16 AM
will944's Avatar
Send a message via AIM to will944
I'm with Makenzie.....bleed the ***** out of everything!
10 E92 M3
13 Jeep GC Limited
98 Jeep Cherokee
87 951
C3 Stingray
Old 11-17-2004, 11:50 AM
If you are using a vacuum pump, is it possible that you are "vacuuming" air past the seals?
I have always been afraid of them - I prefer to pressure bleed, and I have found it works better to bleed a front and a rear at the same time, as it allows full travel of brake pedal.
Done properly, it is a 3 person job, and the procedure is:
-pump gently 2-4 strokes
-hold pedal pressure, say "holding, open"
-open 1 front and 1 rear bleeder
-when pedal goes to floor, say "down, close"
-close bleeders, pump, repeat.....
Old 11-17-2004, 02:33 PM
TCMdocs944's Avatar
Speed bleeders all around would be about $30.
After doing it once with them I am hooked.
It still is kind of a two person job but not really necessary.
I am interested in Gumball's theory of overvacuuming....sound plausable to me. Anyone ever have this happen?
Old 11-17-2004, 03:30 PM
I suppose it is possible in theory to "over vacuum", but after using one I must say probably not, the seal over the bleeder is made with grease.
I was much more pleased with my rigged up bicycle pump and tire valve version of a pressure bleeder.
I should try speed bleeders.
Old 11-17-2004, 04:19 PM
With vacuum bleeding, the bubbles are probably being sucked from around the threads of the bleed valves, especially if you have firm pedals. That's why I hate vacuum bleeding the brakes..you never know when you are done. For $46, I suggest the pressure bleeder Pelican Parts sells. It's worth it. http://www.pelicanparts.com/catalog/shopcart/944M/POR_944M_brakes_pg14.htm#item79
-Dave-
1969 911/3.0l SC
Old 11-17-2004, 06:01 PM
