fuse/relay board removal.
i have yet another long weekend, and so i'm going to try and address some electrical probs that i have. from readings i have taken, it would appear that i may have a prob with wiring from additional fuse board, so i'm thinking about removing the whole shebang, and cleaning/replacing whatever prob i find. has anyone removed these boards/connections, and what level of difficulty, on a sliding scale, from 2 beers, up to 2 cases can i expect?.
note to self: remember to place large extinguisher in garage!
1984 944 na. FR. WILK power prom/dual chip. 2005 buick. daily beater 2002 grand am--better halfs ride. olds 98 royal brougham--gone, but not forgotten. |
I have been wanting to do that to my early 944 as well.
There is the point that many grounds are attached to that should be easily accessable once the ralay / fuse boards are out of the way.... I'm hoping that there is an easy way to remove the boards, if there is hopefully someone will chime in..
944 85.0 Kalahari Beige -- Dead/Gone/NotForgotten (Ran Like a Raped Banshee) 944 85.5 Guards Red Current Stable 944 83 Kalahari Beige manual rack, short 5th gear951 86 Guards Red, pristine TurboYou must not anger the Porsche Gods - you MUST leave one small item unrepaired, lest the Stuttgartians smite thine car with bad Ju-Ju-AF Juvat |
It's a PITA. You have to remove the seat to get any decent angle on the darn thing. One phillips screw and a large moulded pin on each end hold the whole shebang in. One of the moulded pins is in a slot the other in a hole. You have to maneuver the mess about to get them released. Take the ground off of the battery before you do this.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
