Composite Shop Owner, DJ
MixMasterK's Avatar
Send a message via MSN to MixMasterK Send a message via Yahoo to MixMasterK
Instrument Panel Faces
Has anyone here ever converted over to the newer style faces being sold on eBay? Has anyone tried to put these into an '86? There are more things on these gauges than on the OEM style. Is there a better aftermarket substitute that someone can recommend?
Here's a link: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=7936203384&category=33677
'86 944, 5 Speed (Daily Driver)
Old 11-21-2004, 05:23 PM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson Send a message via AIM to bryanthompson Send a message via Yahoo to bryanthompson
They look too ricey for me... Look at his other auctions, K&N filters, fart can mufflers, body kits, euro tails.
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 11-21-2004, 06:52 PM
scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
i have them in my rx7 and i like them
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 11-21-2004, 07:05 PM
seaboltman's Avatar
Thats not too Ricey. White faced gauges arent my favorite during the day, but at night i love them
1987 944 - Wrecked turned parts car
1986 944 - Awesome Auto
Old 11-21-2004, 07:19 PM
livewirevoodoo's Avatar
even with the bulb housing refinished and lighting upgrade, while decend, leaves something to be desired IMO. I want the guages to jump out at me instead of having to focus on them (esp. since i seem to have a compulsive disorder of always checking my temp). those definitely do it. i wonder what sort of wiring is required.
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 11-21-2004, 07:51 PM
you hook up a ground and a power cable then your done
they are a piece of cake to put in.
Old 11-21-2004, 08:01 PM
seaboltman's Avatar
all you have to do is wire them into the headlight wiring
MixMasterK's Avatar
But will these still work on my '86 since the car doesn't have the extra features: antilock, servo, etc.?
Old 11-22-2004, 07:41 PM
seaboltman's Avatar
They should work fine. Just wiring them into a power wire (headlights would work well, seeing as you need them go glow mainly at the same time you are using the headlights) and then wire them up to a ground. Not hard at all.
Old 11-22-2004, 08:15 PM
