Send a message via AIM to drfatz
Audi Transmission parts? HELP!
OK so this has been an ongoing saga....I have been trying to find a 4.11 R&P for my 1985.5 944. So far I have managed to find a company (Powerhaus II) that offers one for $900!!!! no way am I going to spend that when I know (they even told me) that since its not a "Porsche" part they order the Audi equivalent part directly from Audi...and there is no way that it costs them $900.00. So in light of this information I have been trying to figure out what the part # is? Also what Audi transmission have the 4.11 R&P that will fit into my 016K box???? That way I can just buy an old one from a junkyard and pull out the R&P. I am having a really hard time getting the info on the Audi transmission and model numbers. Any help would by MOST appreciated :-) Also is there a higher one like around 5.0?
1985.5 944 NA
-Racing Headers, Cat-less Borla exhaust, New racing Cam, Turbo valve springs, multi angle valve job, big bore throttle body, Eprom, blue printed injectors, throttle response cam,
-Just installed: M030 Suspension with turbo A-arms and hubs. Big Reds with rotors and stainless lines. Turbo sway bars front and rear. Boxter wheels, turbo mater cylinder, and MOMO steering wheel and shift knob.
Just Finished: Clutch, flywheel and transmission...and TONS more!
Old 12-02-2004, 09:37 PM
Send a message via AIM to bluebullet
5.0? jeezus thats getting up there...you would be at 4200+rpm on the hwy at about 70mph. Hondas have a 4.11 or a 4.44 in the Si models..at 80 they are just over 4 grand....they run out of gear around 120 mph.
If you plan to do nothing but autox or maybe small road racing, then go for it..that added acceleration will kick ass. But for street driving, a 4.11 would be fine.
my friend 96 GT mustang went from a 2.73 in the rear (at 80mph we were doing a lousy 2200rpm) to a 4.11 (3200 rpm at 80) We still wound the car out to 130 plus mph, and I could burn the tires on a roll in 1st and 2nd gear.
1985 944 / 2007 335i / 1987 325is / 1985 535i / 1999 528iT / 2006 X5
Old 12-02-2004, 11:58 PM
Take a look at the Audi 5000 Turbo Diesel from the early 80s.
gb
Good luck, George Beuselinck
Old 12-03-2004, 03:58 AM
Rmills944's Avatar
Send a message via AIM to Rmills944 Send a message via Yahoo to Rmills944
My truck has a 5.29 in it... soemthing like a 5.0 isn't unheard of in trucks. Hell, rockwell 2.5 ton axles in military trucks only came in 6.70 gearsets.
Just remember that the lower your ratio is, the thinner the gear gets. You will have a weaker R&P even though it's a more favorable ratio to you.
Ryan
'84 944 moneysucker edition (SFR, Corbeaus, etc.)
'02 Jetta TDI 280Lb/Ft 145Hp @ wheels. RC2 PP357's
Old 12-03-2004, 06:39 AM
why not just use smaller diameter wheels & tires?
Tom
Early '85 944
Old 12-04-2004, 04:59 PM
