seaboltman's Avatar
Gauge Cluster Grounds - Where are they!
Ok i went to clean the grounds for my gauge cluster today and... Ill have to admit that i couldn't see where it was grounded to. During something later today i saw a few grounds that are right under where the fuse box is, on the inside of the car, Are those the ones for the gauges? Thanks for the help.
1987 944 - Wrecked turned parts car
1986 944 - Awesome Auto
Old 11-27-2004, 09:11 PM
When I was having trouble getting my gauge cluster to light up, it was the brown wires that you're talking about that fixed my problem. Hope it works for you.
Old 11-27-2004, 09:57 PM
livewirevoodoo's Avatar
Yea.. the grounds inside the car under the fusebox.. Driver's footwell. I cleaning those and my seatbelt light stopped flickering. Haven't seen any *behind* the gauge cluster on the few occasions that I took it out. On the autos, I've also found grounds:
Back of rear hatch (for tail lights i presume?)
Front of car, under hood, driver's side by radiator/driverside headlight
Drivers side, under hood by windshield.. Underneath that plastic housing that lets the rain drain off.
And interestingly enough (at least on autos).. underneath the car, about 3/4ths toward the rear, near the wheel wells.. Dunno wtf those are for.
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 11-28-2004, 10:29 AM
