Can my car run too cool
what are the ill effects of running a 944 without a thermostat.....
Old 11-28-2004, 07:01 AM
the heat will not work..and teh car will never get to temp if you live in a cool climate...Unless youl ive in Florida ...I wouldnt do it
Current: 1973 914/4 project. FOR SALE
Old 11-28-2004, 10:09 AM
Send a message via AIM to bluebullet
well you can be TOO cool. The car will never warm up to temp and you will run rich because the DME increases fuel while cold to get it warmed up faster. You will just burn a lot of gas, and fill the exhaust chambers with carbon deposits. Not to mention your 02 would prolly take a dump from not cycling.
1985 944 / 2007 335i / 1987 325is / 1985 535i / 1999 528iT / 2006 X5
Old 11-28-2004, 11:41 AM
The thermostat also acts as a restrictor, forcing the coolant to travel slowly enough to transfer heat from the metal to the liquid.
Therefore you are more likely to over-heat the cylinder liners and the head. The temp gauge might show a low temp, but the gauge will not show hot spots.
Old 11-28-2004, 03:30 PM
what exactly would be too cool......where on the guage......?????
Old 11-29-2004, 06:39 AM
Zero10's Avatar
Send a message via ICQ to Zero10
I would say if it always runs on the bottom 1/4 of the gauge, it's running too cold.
That said, there are low temp thermostats and fan switches, that will keep it that low, so I'm not sure they're a good idea either.
As a general rule, the temp gauge should be between 1/4 and 1/2, that's where I like it best, any higher and I start getting nervous (unless it's 30 degrees, and I'm sitting in rush hour traffic, then I know it's normal)
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 11-29-2004, 07:20 AM
