Send a message via AIM to projekt70chevel
Unhappy still not that much brake pressure
I'm been leaving a destruction path now that I've got the new master cylinder on and I'm not getting any brake pressure STILL, it gets to a point where its almost like its bouncing off something or going past a point. Someone show me the light in my brake problem.
Old 11-30-2004, 06:05 PM
im not quite sure, but i heard the master cyclinder and the clutch have a relationship.. maybe someone can enlighten you and me if im wrong..more study needed here..
1988 924s mars red
coastal cruzer
Old 11-30-2004, 06:09 PM
Wolf1's Avatar
I believe that you are thinking of the clutch master and slave cylinders.
Projekt70chevel, is talking about his brake master cylinder.
75 914 - Undecided.
80 931 - Gone, but not forgotten.
72 914 - old toy- sold.
And a whole bunch of German scrap metal shaped like 924's.
Old enough to know better, and stupid enough to do it anyway!
Old 11-30-2004, 06:13 PM
seaboltman's Avatar
I believe that the Brake master and clutch master cylinder are the same thing in our cars. Bleed your clutch as well as your brakes. Make sure you do it in this order
Rear Passenger, Rear Driver, Front passenger, Front driver. Then do the clutch, and see what happens.
1987 944 - Wrecked turned parts car
1986 944 - Awesome Auto
Old 11-30-2004, 06:35 PM
The brake and clutch master cylinders are seperated..as they are in all cars. The brake master cylinder reservoir is shared with the clutch sytem however. Which is why clutch master cylinder leakage causes the brake fluid level light to come on.
Hopefully you installed the correct master cylinder, there are two different makes depending on the booster type. After that you need to bleed the system correctly, I always recommend using a pressure or vacuum type bleeder to make sure the fluid is completely replaced.
Yes, you should always bleed the clutch system too.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 11-30-2004, 07:32 PM
