88_944's Avatar
Front Calipers sticking
My front wheels don't spin freely like before. Could the Master Cylinder valve spring be sticking that causing the Front Calipers to grab the disc? I think inside the Master Cylinder the fluid is not moving back in place. This is my frist time around with the brake system.
See the Master Cylinder in Action here.
My Black 944
My Gaming Forums. Xbox360gen.com
Old 12-07-2004, 05:34 PM
jm951's Avatar
Maaaybe. I'd think it was more a result of not regularly changing brake fluid. Brake fluid is hygroscopic, meaning it absorbs water from the air. If the fluid isn't changed, the moisture in the brake fluid can lead to corrosion in the entire brake system. Have you bled the brakes lately?
86 951- again on the road, but needing some more TLC
82 931- again among the rolling
"If yer paint aint chipped, you aint passin nobody."
Old 12-07-2004, 07:08 PM
88_944's Avatar
I just did a clutch job and I added new fluid untill the Slave Cylinder was all bleeded.
My Black 944
Old 12-07-2004, 11:19 PM
SoCal Driver's Avatar
Check to see if your brake pads have worn down at an angle. If the caliper assembly is not free to move this can happen.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 12-09-2004, 06:04 PM
