winter-hater club member
nynor's Avatar
installing valve seals
i will be pulling the valves tonight on the head i am installing. i will number them to be sure they go back in the right places.
i have new valve seals that came the gasket kit i purchased. how do i install new valve seals?
remember, this is my first time doing this work and i am mechanically challenged...
"COOL PRIUS!" - Nobody Ever
Old 12-10-2004, 08:24 AM
AFJuvat's Avatar
There is actually a tool to install them - you can get similar results by ousing a small piece of PVC pipe.
Use a little oil on the seals to get them to slide.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 12-10-2004, 05:28 PM
nynor's Avatar
thanks, afjuvat
Old 12-10-2004, 08:50 PM
ae1969's Avatar
Send a message via ICQ to ae1969
You can also use a 1/2 inch deep socket.........and just lightly tap them in........you will easily hear them bottoming out.
....and if by chance these are the stock valve guides (smooth) you should use an adhesive to hold them in.......I had to use loctite 514. If you have guides with the cutouts then its not a problem the guide will dig into the seal.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 12-10-2004, 09:16 PM
Send a message via AIM to ike229
What kind of adhesive should one use to hold new valve seals in place (if you have the older style guides). I see ae1969 used loctite, is this what is most commonly used ?
'05 M3 - Alpine White
'88 924S - Black
'91 318IS - Alpine White
'88 Honda Hawk
'75 Honda CB360
Old 12-23-2007, 12:31 AM
