Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 924/944/968 Technical Forum
Mein Gott!
Panzer909's Avatar
What causes cracked heads & blown head gaskets?
Last week, a friend of mine developed an engine problem where its eating coolant and we're suspecting either a cracked cylinder head and/or head gasket. The car already had a new gasket job about four years ago, and he takes religious care of it. He never overheated it or anythuing like that.
It got us to thinking - exactly what is the main cause of a blown head gasket? It takes an awful lot to crack a cylinder head, so is there a sure fire way that this happens beside age?
Johnny
1987 944S
1984 944 (R.I.P.)
1972 Triumph TR6 - 100% trouble free between breakdowns
2003 BMW 325xi
Old 12-14-2004, 06:50 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Send a message via AIM to AznDrgn
pretty much overheating and things hitting the head are the main cuases of cracked cylinder heads. Head gasket failure however could just be bad installation, cheap gasket, or high compression either by forced induction, nitrous, or pistons.
Are you sure it's a head gasket? does the car blow white smoke? is there water in the oil or oil in the water?
'91 Jeep Cherokee 4.0L HO - Daily driver
'83 Callaway 944 2.5L turbo - Soon to be daily driver
'83 Porsche 944 NA - sold
'78 Porsche 924 NA- RIP
'89 Porsche 944 S2 - Parted
Looking for a nice 944S for a daily driver.
Old 12-14-2004, 07:33 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Wel...if its not overheating, and not blowing white smoke, then you propbably have a leak somewhere. I had one 944 that went trough coolant like nobodys biz...But I caould never find coolant under the car.
Turns out it was a bad pressure cap causing it to spit teh coolant out while I was driving...My wife was behind me when it happened. Got coolant all over the BMW.
Current: 1973 914/4 project. FOR SALE
Old 12-14-2004, 07:54 AM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
TCMdocs944's Avatar
Heat.
The only thing preventing faster speeds, long space travel, unlimited production of energy...the list goes on...
is that all of these things produce heat which causes things to bend, crack and deteriorate.
I am currently working on a cold-fusion reactor for my 944. When I get done I will give you guys the plans.
Uhhh, overtorque plus heat can definately cause something to break.
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 12-14-2004, 08:42 AM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Administrator
Z-man's Avatar
A couple of years ago, I lost my H2O pump while driving at the track. As soon as the temp guage went to red, I shut the car down immediately. I actually drove the car home from the track (4 hour ride) and over-heated once more, but again, I shut it down right away.
Could that have been the start of a small crack on my head? Perhaps.
This summer I developed a situation where the coolant was leaking into the head quite dramatically on the track. I was adding close to a gallon of coolant/water to the system when driving on the track. In street driving, while I did have to add some water, it wasn't as significant. Kept an eye on the temp guage, but it never went too hot, even on the track. Throughout the summer, my mechanics tried everything - replaced seals, bypassed the coolant passages flowing through the throttle body....all the 'easy & cheap' stuff. Still, the problem persisted.
Finally in August, my oil pressure sender unit got fouled due to all the water in there, and the car lost oil pressure. At that point, the head came off. The head gasket was a mess, but didn't really show any signed of where water was getting into the cylinders. The head was magnafluxed, and a small crack was indeed found above the #2 cylinder. So small is the crack that you cannot see it.
What caused my head to crack? I suspect a combination of the following:
1. The loss of my H2O pump a couple of years ago, and the subsequent overheating, even though I didn't drive it once it got in the red.
2. The fact that I'm pushing my car while on the track - I'm at or near redline for 20 minutes at a time!
3. My engine has 150,000 miles on it. And while I've only had my car for 30,000 of those miles, that is still a lot of wear and tear on a motor.
Just my thoughts,
-Z.
1989 944S2 - June, 2001 - January, 2014
Visit my homepage!
Old 12-14-2004, 08:46 AM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
was the head torqued down correctly when the head gasket was replaced?
Improper sequence can warp heads, cause cracking, blow gaskets, etc.
1987 944S, needs crank work
1992 Jeep Sahara YJ 4.0
2001 Harley FXST
1981 VW Rabbit diesel
1984 Isuzu P'up diesel
Old 12-14-2004, 09:20 AM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Mein Gott!
Panzer909's Avatar
Hmm. We are not 100% certain that its the gasket or crack in the head, but its pointing in that direction fast. We're doing all the "easy" possibilities so far - replaced cap, went over it at high idle for external leaks, and he even did the oil cooler seals last month.
In looking at his records, the head was removed and even had machine work four years ago. This was right before he bought it. We're not sure about their process (torqing it correctly, etc.) but:
1. It needs topped up with coolant about every 1 1/2 weeks or so with NO external leaks. I even checked the infamous heater valve deep in the engine bay.
2. There's no plume of smoke from the exhaust (other than the fact that its really cold here in PA now).
3. The car drives/idles/accelerates fine and always has.
4. The oil looks fine when drained and no real sign of milkshake.
I'm just deducing that the problem is something REALLY bad. A search for previous threads on coolant loss point to cylinder head issues. We just don't know what he's gonna do.............
Johnny
1987 944S
1984 944 (R.I.P.)
2003 BMW 325xi
Old 12-14-2004, 11:15 AM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
ae1969's Avatar
Send a message via ICQ to ae1969
How about a compression test and/or leak down and the mystery will be solved.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 12-14-2004, 11:45 AM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
Administrator
Z-man's Avatar
Same with my car as the crack developed.
I didn't have any plume of smoke before the head was replaced either!
Ditto.
Same with mine, until a certain point, and then the milkshake appeared!
-Z.
Visit my homepage!
Old 12-14-2004, 12:16 PM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
Administrator
Z-man's Avatar
Nope - that's not going to help diagnose a potential cracked head. I had the following leaddown numbers with a cracked head: 2%, 2%, 3%, and 4%. (Factory spec is 2%, IIRC.) Not bad for a motor with 150,000 miles and a cracked head!!
The problem the compression / leak down test is that they are done when the engine is cold, and the crack is much less evident then. But head up the head (ie magnaflux it) and you'll be able to spot the crack right away.
IF you take the head off, definately Magnaflux it - it will show if it is cracked or not.
Good luck!
-Zoltan.
Visit my homepage!
Old 12-14-2004, 12:18 PM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
Pull the plugs and using a strong flashlight, look into the cylinders. If one or more are spotlessly clean, or at least substantially cleaner than the others that's a sign of a coolant leak into the cylinders. The coolant will "steam clean" the affected cylinder, where as the rest will probably have some amount of combustion residue in them.
If you know a mechanic with a borescope, that's a better way of looking into the cylinders
Mike
'92 968
'01 VW Jetta TDi
Old 12-14-2004, 12:19 PM
  Pelican Parts Technical Article Directory    Reply With Quote #11 (permalink)
Eric 951's Avatar
Johnny,
you scared me for a minute--thought you were talking about the "S". good luck in the diagnosis.
Is your clutch still good?
PS--you are invited to my New Years' Eve party at my house--start around 7 PM--bring a friend if you want.
Eric
83 911SC
76 CB 750 Cafe/78 CB 750F/83 VF750F/75 CB750F
76 F150 Bicentennial Edition
Old 12-14-2004, 12:21 PM
  Pelican Parts Technical Article Directory    Reply With Quote #12 (permalink)
Mein Gott!
Panzer909's Avatar
Originally posted by Eric 951
Johnny,
Well, Eric and fellow board members, I'm afraid that I've got a very heartfelt and tearful confession to make................
I AM talking about the "S"
The problem could be so bad that I'm already in denial! I need a beer - and it isn't even Friday yet. The good news is that the "S" was being pulled from frontline driving duties and is safe & sound in the garage for the time being. I just bought a BMW 325ix for winter driving (yeah!) But at the moment, my budget is nowhere near what is required to R&R a cracked 16v head, so I'll probably have the car just lay low until springtime. Then it will be time to adress the 944$ problem more seriously.
Eric, thanks for the invite - I might just take you up on it! I'll be in touch soon either way.
Johnny
1987 944S
1984 944 (R.I.P.)
2003 BMW 325xi
Old 12-14-2004, 01:03 PM
  Pelican Parts Technical Article Directory    Reply With Quote #13 (permalink)
ae1969's Avatar
Good luck!
-Zoltan.
Uhmmmm I was actually ruling out a bad headgasket etc.............. If your tests come back good on a cold engine you can rule these things out. (99% of the time)
There is no point of considering a cracked head without doing those two tests.
Otherwise its all guess work.
P.S as was mentioned above pull the plugs and take a good look down in the cylinder hole and the actual plugs. If one is getting steam cleaned it will be pretty obvious.
P.S.S diagnosing vehicles is like medicine. Differential diagnosis can always help. Assume everything and rule out those that don't apply........and you are left with what it is.
Old 12-14-2004, 01:20 PM
  Pelican Parts Technical Article Directory    Reply With Quote #14 (permalink)
fast924S's Avatar
Send a message via AIM to fast924S
Or you could just Run the car till it heats up and then do a compression and leak down test, theses test should never be done cold, wont be accurate. Also check the plugs to see if any of them look like they are burning coolant. Also you can do a pressure check on the cooling system, Get the tool warm up the car pressurize the system and see if the pressure drops, if it does then you have a bad head gasket
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 12-14-2004, 01:37 PM
  Pelican Parts Technical Article Directory    Reply With Quote #15 (permalink)
Eric 951's Avatar
Johnny,
Ouch--sorry to hear I know those S heads are $$$. Although on the bright side--I always liked the 325ix--pretty slick snow machines. Just let me know regarding the party--should be fun.
Eric
83 911SC
Old 12-15-2004, 05:50 AM
  Pelican Parts Technical Article Directory    Reply With Quote #16 (permalink)
Why do you think the head is cracked vs. being warped? I've seen lots of warped heads, especially cars that see the track. Easy to fix on 8V engine, maybe a little more work on 16V. In addition to eating coolant, you might notice tell-tales of water evaporation at the point where the head meets the block.
Old 12-15-2004, 11:22 AM
  Pelican Parts Technical Article Directory    Reply With Quote #17 (permalink)
2001 c4 engine problem
Hey guys, I have the same kind of problem. I am eating coolant as welll. And i dont know where it goes. I took it to porsche and they said there is moisture/coolant in cylinder one. The engine light flashes on startup and stays on after that. There is no oil in the coolant tank, but i think there is coolant in the oil because i drained the oil and it was very thick and black. Any ideas what the problem could be? i was thinking cracked head or blow head gasket. Any pointers would be great... thanks!
2004 c4 tip.
Old 03-28-2011, 12:50 AM
  Pelican Parts Technical Article Directory    Reply With Quote #18 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
*2001 c4 tip
Old 03-28-2011, 01:03 AM
  Pelican Parts Technical Article Directory    Reply With Quote #19 (permalink)
Proprietoristicly Refined
John_AZ's Avatar
2004 c4 tip.
I enjoy reading old posts-2004! and you actually did search.
I would ask the 911/996 forum members for the best suggestions.
GL
John
1988 924S 77K July 2017 ...+ 1987 924S 145K DD (+15K est. bad odometer)
Old 03-28-2011, 05:51 AM
  Pelican Parts Technical Article Directory    Reply With Quote #20 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
