squealing brakes
Anyone experienced brake squeal on rear 944 brakes?Mine have just started and it seems to get worse as you drive.Knackered pads?
1989 guardsred 944s2 cabriolet,
1983 metallic claret 924 lux (sold)
Old 12-19-2004, 03:05 PM
Send a message via AIM to toolboy62 Send a message via Yahoo to toolboy62
A lot of disc brakes squeal, and it doesnt' help that most of the pads sold for a 944 are metallic. Here's what I do whenever I have a car with brakes that appear to be in good condition but still squeal:
first, remove the pads and calipers. Clean up *all* moving surfaces on the calipers and carriers with a wire brush and then coat lightly with anti-sieze paste. Then take the pads and knock the corners off with a flat file, esp. the leading edge. just a little bitty chamfer is enough. Then clean the back side of the pad and apply a little more anti-seize there, or else some of that brake anti-squeal goo. I use anti-seize just cause I always have it for other jobs and that way I only buy one bottle of stuff Reassemble.
I just did this to the front brakes on my 944 yesterday (while trying to stop a different noise that happened only intermittantly, I didn't fix that noise... see "help me - rear end noise" thread for details) and they do not squeal at all now even though the pads look like chunks of sintered iron (Metal Masters? dunno, were installed before I got the car) still a little squeal from the rears but oh well, it's 200% better. It used to sound like a frightened little girl when doing a light stop, now it's much less embarassing. I should have done it a long time ago.
Since you've got the anti-seize paste out, it would be a good idea to put a dab on each stud, and a thin coat on the wheel where it touches the hub (don't forget the center bore) to forestall any corrosion problems in the future. (can you tell that anti-seize is one of my top three favorite automotive chemicals? My other two are Kroil and Berkebile 2+2 carb cleaner.)
good luck,
nate
1988 944... and a bunch of other cars
Old 12-19-2004, 03:23 PM
oh yeah it could be the pads wearing down too. Some pads have a "squeaker" on them that makes a racket when the pads are almost down to the rivets. But I thought all 944s had the brake pad wear sensors, so I didn't think of that possibility. (the ones on my car have the sensors, and no "squeaker")
nate
Old 12-19-2004, 03:26 PM
Thanks nate, i think i'll get it in the garage to check it out.Ade.
Old 12-19-2004, 04:02 PM
