winter-hater club member
charcoal canister help, please!
sorry about the post in parts for sale section...
i bought a new charcoal canister, because mine was simple GONE. i took it out of the box and it is much larger than i expected: it is about eleven inches tall and about 4 inches in diameter. also, it seems there are three intake/outlet holes. while it may seem that they are self explanatory, they are labeled tank/luft/motor, for the life of me, i cannot figure out how the hoses are supposed to be routed. being that i didn't ever see the old one, just have always smelled gasoline in its absence after filling up, i have not a clue. PLUS i am mechanically challenged. how do i install the thing? what is the hose routing? and is it kosher to install it under the hood instead of in the wheel well? (sounds blasphemous, but i don't know if the bugger really should fit there - and i know it would be much easier to rig a mount for it under the hood.)
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
Mein Gott!
Hey hold it up in a mock position under the wheel well, and if it doesn't fit - it doesn't fit. No use try to hack job it in there. "Luft" means "air" in German (if that helps). Where did you pick the part up?
Johnny 1987 944S 1984 944 (R.I.P.) 1972 Triumph TR6 - 100% trouble free between breakdowns 2003 BMW 325xi |
actually, i just checked it out. it does fit. i didn't see the upper bracket, as it is way up there. i got the part from pelican. i think it is an updated part but should work anyway. the part number starts with a 993. i am going to tee the one hose coming from the engine compartment and and attach it to both the engine/tank fittings. the luft fitting is obviously the breather to outside air. i think it will work just fine.
