Proprietoristicly Refined
John_AZ's Avatar
Oil Pump drive gear/sleeve removal
Does anyone have an easy soution for an oil pump drive gear/sleeve removal that appears to be stuck on the woodruff key/ crankshaft. Seasons Greetings.
John_AZ
1987 924S 100+ Miles
Previous engine work unknown
Old 12-23-2004, 10:25 AM
you got to pull the woodruff key, and then you should be able to slide the gear off. You might need sand some right at the woodruff key area to remove some burrs to get it to slide past that area.
Rick
99 996C4
06 525XI
87 944S - Sold
77 924 - Sold
Old 12-24-2004, 06:17 AM
