I need to get to the main seal!
So i'm tearing down and resealing my engine and what's this!? I can't pull the cover out to get to the main seal....Why
must something always prevent me from progressing with my projects, why!!???? OK, that's better, so guys, how do i go about it. It seems that whoever worked on this before liked using lot's of silicone and glues...and in the hayne's manual(i know, but i needed some kind of reference) it say's it should pull straight out.....well, that's not working, it's stuck and does not want to move. I'd really appreciate your help fellas. I got the week off and I wan't this to be on the road really bad. Thanks again......:D http://forums.pelicanparts.com/uploa...1104813011.jpg http://forums.pelicanparts.com/uploa...1104813036.jpg http://forums.pelicanparts.com/uploa...1104813053.jpg |
Ger a seal puller and hook it out.
Also, have you removbed the washer and the oil pump sleeve? Sometimes that makes it easier AFJuvat |
oil pump sleeve? you mean from behind the main seal?
| All times are GMT -8. The time now is 01:55 PM. |
