Interior light
Recently got around to replacing the lights in the hatch area and between the sunvisor - but they only come on when either the hatch or the passenger door is opened. Are they supposed to come on for the driver door? If so, any input on where to start checking connections?
1983 944 with S2 motor, trans, suspension and exterior -- crunched parts car 1987 944 -- soon to be 1987 944S2 |
Mine was doing the same thing so i ordered the door switches to replace them. As i was taking the old one off, when i started to pull the wire off the old switch the lights come on. Maybe it was just making a bad contact or something. If that's not it, you might have to replace the switch (not very expensive).
1986 Guards Red 944 Auto 1995 Chevy Tahoe 3-3 drop, w/ 22's 2006 GMC Envoy 1989 Dodge Shortbed(project) |
Yup. Pulled it out and got it to light up by ground it to the body. Looks badly corroded. New one on pelican is $7.75. Thanks!
That'll do it... I had the same problem, i pulled the switch out put it back in... and voila, grounded.
