That Guy
Techno Duck's Avatar
air / fuel ratio gauge with FRWilk chip
I was looking around at air fuel ratio gauges and the best way to wire them too work with the DME. Then i realized, the FRWilk chip does not use the O2 sensor. So that would essentially make any readings from a a/f gauge useless right?
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 01-06-2005, 05:58 PM
scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
it wouldnt make it useless. you would still have the sensor and you could still hook one up and read what it says. but the stocker isnt a good way to tune.
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 01-06-2005, 06:04 PM
fast924S's Avatar
Send a message via AIM to fast924S
with WILKS chip installed and my HR A/F gauge Im almost always above STOC. Then agian I have bumped up my Fuel pressure too. If you use the A/F gauge on a stock setup it moves all over the place but with wilks chip installed it is more controlled. If it was aviable when I first did my mods I would have went with a WIDE BAND 02 sensor and A/F gauge
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 01-06-2005, 06:51 PM
could someone direct me on where to get a wideband O2? Also will it work w/o the wilk chip?
1983 944 Copenhagen Blue
MODS: ENGINE: Firebraid 9mm plugwires. Weltmeister Throttle Cam, Dansk exhaust. lo-temp thermostat & fan switch, aluminum radiator. SUSPENSION: H&R 250lb springs, KYB GR-2 struts(front) Bilstien Shocks(rear), Racing Dynamics strut bar, APPEARANCE: 15" Phone Dial wheels, a-pillar w/ VDO H2O and volts gauges.
1987 944-S Montego Black
-needs your help
Old 01-06-2005, 07:45 PM
Super Moderator
nize's Avatar
hope you got lots of spare cash, wideband gets expensive. currently the best pod-style wideband is the one by aem;
http://www.rpmoutlet.com/aemgauge.htm
there should be a (possibly cheaper) one available from zeitronix around february or march, and the guys on rennlist are planning on making a group discount buy, in case you can wait;
http://www.zeitronix.com/
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 01-06-2005, 07:54 PM
That Guy
fast924S, how do you have the gauge hooked up. Did you splice into the DME harness for the a/f ratio gauge? Im just curious to see how others have done it.
Jon
Old 01-06-2005, 08:02 PM
Super Moderator
nize's Avatar
the best way is to splice into the DME for narrow band.
for wideband, you'll have to run a seperate line.
there's a LOT of info on this install on rennlist;
http://forums.rennlist.com/rennforums/showthread.php?t=170416&highlight=gauge
and;
http://forums.rennlist.com/rennforums/showthread.php?t=159995&highlight=gauge
and;
http://forums.rennlist.com/rennforums/showthread.php?t=143445&highlight=autometer
Old 01-06-2005, 08:29 PM
fast924S's Avatar
Techno, Im piggy backed into the connector thats on the firewall, per the directions from Huntley Racing
Old 01-07-2005, 10:11 AM
fast924S's Avatar
P/S Nathan it will work both with and with out FR-wilks chip
Old 01-07-2005, 10:13 AM
So for non FRwilked cars, you have 2 sensors, one narrow for the DME and one wide for the A/F gauge?
-needs your help
Old 01-07-2005, 03:07 PM
fast924S's Avatar
ummm I dont understand? All our 944 and 924S cars have a narrow band 02 Sensor. If you wanted to run a very accurate A/F guage then you will need to install a wide band sensor and the A/F gauge, so yes you would keep the stock o2 gauge for the DME and install a Wide Band one. But if you just looking to get the basic idea of what your A/F ratio is then I would just run a A/F gauge off the stock 02 sensor
Old 01-07-2005, 06:02 PM
fast924S's Avatar
Looky looky, I found a sweeet wide band kit for like $300, Its on a toyota performance site but it looks like its universal
http://www.urdusa.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=0019&Category_Code=
Old 01-07-2005, 07:05 PM
Super Moderator
nize's Avatar
that's $350 dude. you can get the zeitronix which is way better for $279
http://www.zeitronix.com/Products/zt2/zt2.htm
Old 01-07-2005, 07:19 PM
fast924S's Avatar
nize that is one sweeet setup and for the price you cant go wrong
Old 01-08-2005, 12:44 PM
Super Moderator
nize's Avatar
yeah, i'm just waiting for them to come out with an add-on pod style gauge like the aem wideband. should be around february or so.
Old 01-08-2005, 04:49 PM
