-   -   Can't remove license plate bracket (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/200780-cant-remove-license-plate-bracket.html)
Chuck944 01-10-2005 04:32 AM
On the front of my 1985 (early) 944, I can turn the screws (barely) but they don't back out and they don't seem to be letting go of whatever they are holding on to.
adrian jaye 01-10-2005 05:56 AM
have you tried soaking them in some penetrating fluid,
if not then CAREFULLY drill them out ?
HTH
Ade
btsave 01-10-2005 07:13 AM
Easy fix, remove from bumper (two bolts located on bottom - use socket wrench).
Then it's easy to use a socket to stabalize the inside bolt.
Takes about 15 minutes.. Use rubber stop for remaining holes.
