Valve cover bolt torque
Can someone tell me what the valve cover bolts should be torqued to?
Thanks,
Geoff
Old 01-11-2005, 09:59 PM
pokey's Avatar
Send a message via AIM to pokey
German spec... Gootentite.
Seriously, I don't remember but if no one beats me to it I'll post tommorow.
Still looking for the right deal on another P-car
1968 BMW 1600 2 liter
1956 Ford F250
1955 BMW R69
1999 Range Rover Callaway #011 of 220 (Yeah, as in Callaway Corvette...)
Old 01-11-2005, 11:01 PM
adrian jaye's Avatar
there less than 10, thats for sure, I "THINK" about 7ft/lbs
dont ask me how I know, but they snap great at 15ft/lbs
oh, hang on, what car are you talking about.,....
pls post your car details in either your signature or in your details so we know, its def, 7lbs for an s2 engine
The fear of God is the begining of wisdom <><
NotJustPorsche
Subscribe: notjustporsche-subscribe@yahoogroups.com
Old 01-12-2005, 02:35 AM
Send a message via AIM to hpaulb
The Haynes manual says 17lbs. Someone check this as I'm going to be installing mine in the next few days.
87 924S 107k (miles) yellow
1969 Firebird Coupe (Full frame off restoration.)
98 BMW 740i
2020 Subaru Outback and 2019 Crostrek.
Old 01-12-2005, 07:13 AM
winter-hater club member
nynor's Avatar
14.6 lbs (20nM). just did mine 3 weeks ago.
"COOL PRIUS!" - Nobody Ever
Old 01-12-2005, 07:31 AM
ae1969's Avatar
Send a message via ICQ to ae1969
I guess it all depends on what car geoff drives........
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 01-12-2005, 07:53 AM
IT "depends" on the car
check your model otherwise, snap goes your bolts !
trust me I know how to snap them properly now !
NotJustPorsche
Old 01-12-2005, 08:33 AM
Oops, I have an '88 944S......
Old 01-12-2005, 08:43 AM
its not the 7ft lbs, which is the s2 engine,
i "THINK" its 15ft/lbs somone pls confirm that
NotJustPorsche
Old 01-12-2005, 09:02 AM
944S and 944S2 use the same valve cover and bolts. The Porsche recommended torque is 10NM (7lb ft).
Make sure you put a small amount of sealant on the new seal at each corner where the cam bearing housing attaches to the head.
The old sealant is normally visible when removing the cover.
Always replace the round seals in the valve cover for the spark plugs and also the seals for the fixing bolts. ..those parts may come with the gasket kit depending where you buy it.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 01-12-2005, 12:48 PM
Thank you! I'll be sealing the corners.......that's why i'm replacing the gasket, as the previous owner didn't seal them when he rebuilt the engine!
'88 944S
'90 Spec Miata
Old 01-12-2005, 12:57 PM
TCMdocs944's Avatar
retorque in 6 months or so.
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 01-12-2005, 12:58 PM
No, you don't need to retorque 944S/S2 cam cover bolts. What would be the point?
Old 01-12-2005, 01:57 PM
TCMdocs944's Avatar
oops, not sure about the S
On my early the bolts were loose after the gasket seated...about 8 months....showed up as a mysterious oil leak moving appearing near the oil cooler.
Old 01-12-2005, 03:42 PM
If the bolts on a 8V engine came loose then something wasn't right in the first place. If it was with a head gasket failure or similar then probably the head gasket face for the cam box was/is still warped or sealer was used on the gasket. The bolts do not come loose.
Old 01-12-2005, 03:45 PM
gtroth's Avatar
Don't know if you've taken the bolts out yet, if not you might wake them up a bit by tapping the hex socket gently with a hammer. Then go slow - those bolts will break on you during removal, and they're surprisingly pricey in addition to the pain of extraction. And I wouldn't reinstall without antisieze, but other opinions may differ on that. And it's 10Nm, 7ft lb, as Britwrench already said (as if you'd need further confirmation...).
Britwrench - what do you mean by "seals for the fixing bolts"? The grommets that go around the cover bolts?
1995 993C4 guards red
1988 944S alpine white
Old 01-12-2005, 04:54 PM
Yes, those seals..they tend to get hard due to the heat, so now is the time to replace them. You will need 13 of the seals, 928 104 115 02.
And yes, the bolts do tend to break and you need to be careful.
Old 01-12-2005, 05:28 PM
gtroth's Avatar
Hmmm, yes, I probably should have replaced mine when I replaced my chain tensioner. Not leaking yet...
Incidentally, geoff_pdx, how many miles are on your chain tensioner / chain tensioner pads? If you haven't had a chance to search about that, you'll need to. That'll kill an "S" if it fails.
Old 01-12-2005, 05:46 PM
