brake fluid light
Hi
Last night my brake fluid light in the dash started flickering on and off. Sometimes it would go on and off quickly for a few seconds and then stop. Sometimes it would come on, stay on for between 2 and 20 seconds and then shut back off again. it would also stay off for a few minutes at a time as well. Basically its completely random. I went to top the fluid tonight, thinking it was low and dreaded having a small leak, but the reservoir is full. Does that mean that its just the connection in the warning light somewhere? Any ideas? Thanks!
89 944S2
Old 01-12-2005, 03:31 PM
TCMdocs944's Avatar
Sounds like a gremlin but...
Are the connections on the reservoir clean and tight....(first bet)
Anyone know if the late light is a pad warning as well?
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 01-12-2005, 03:35 PM
SoCal Driver's Avatar
Check the switch on the parking brake lever. Lever may not be all the way down of the switch bracket needs a bit of adjusting.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-12-2005, 04:01 PM
mine started like that. I would check the fluid and everything would be fine. Then I noticed the light coming on more and more..... THen finally it would just stay on. THe i would fill it up wiht fluid and then my shoes would be greasy and the carpet felt greasy. I drove it like this thinking it was oil out of the parking lot at work..... THen the unthinkable happened. I mashed in the clutch it went to the floor....... let out the clutch........lifted the foot up.........clutch still on the floor and then it finally came up and tapped the bottom of my shoe....I then got to learn how to install a clutch master on my car........It wasnt that bad though.
85 944. throttle cam. k&n cone. jacobs wires. Msd coil.glass pack... getting ready for drivers ed. daily driver
90 944 S2 cabrio: custom roll bar,18 inch TSW wheels,K&N filter, drilled zimmerman rotors
Old 01-12-2005, 05:42 PM
The fluid light is not the same as the brake pad light, at least my s2 has a different sensor for each. id guess its the same on all cars, but could be wrong.
My fluid light does has stayed off for 20 miles or so now, so maybe my car was just fen with me. however it does sound like it could be the beginning of projektporsches problem. thatd be great if it was the master. i guess ill see how it goes
89 944S2
Old 01-13-2005, 06:43 AM
