TCMdocs944's Avatar
Question Larger diameter rear wheels ?
I have Boxster 16" wheels on my car and am thinking of going with 17" in the rear. I would lower it with the eccentric nuts to keep it level and use a tire with the same size sidewall.
Other than weight (17's weighing more),
Are there any real performance / suspension problems created by this?
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 01-18-2005, 05:13 PM
Re: Larger diameter rear wheels ?
Unless you have something else in mind, I won't need to lower the rear using the eccentrics to fit 17 inch wheels and tires.
Even if the weight of the the 16 inch wheels/tires were the same as the 17 inch wheels/tires, the increased diameter of the wheel moves the mass of the wheel further out from center and this requires even more power to turn the larger diameter wheel.
Mark
'86 944NA
'10 VW Golf 2.5 5sp
'99 BMW 540i Sport Wagon
Old 01-18-2005, 07:39 PM
TCMdocs944's Avatar
Well,
I did have in mind going with a larger, meaner tire.
Somehow low profiles don't really look that great on 944's to me.
Old 01-19-2005, 11:12 AM
