Send a message via AIM to hpaulb
87-924 antenna question
My car has power everything I thought. I went to remove the antenna on the front drivers fender behind the canister because it is stuck 8 inches up and found it's just a tube. Presume its a non powered rod. Now the question is, was this an option and can I put a powered one as a direct replacement. Mechanical fit?
87 924S 107k (miles) yellow
1969 Firebird Coupe (Full frame off restoration.)
98 BMW 740i
2020 Subaru Outback and 2019 Crostrek.
Old 01-19-2005, 06:19 AM
SoCal Driver's Avatar
Get a good after market electric antenna. Works in my early 944.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-19-2005, 06:58 AM
