About to Install Rear Koni's - Advice!
I am assuming this will be very straight forward, but maybe I am wrong.
Does anyone know of a location for a quick tutorial with pictures for installing rears on a stock '87 NA? I searched but found nothing. I had assumed I just jack it, off with the old - on with the new...but do I need to do anything with the springs? Compress them? Other? Please advise. Pix would be great if you have them. Thanks, Dan
Dan in Pasadena '76 911S Sahara Beige/Cork |
Off with the old, on with the new. Pretty straight forward.
75 914 - Undecided. 80 931 - Gone, but not forgotten. 72 914 - old toy- sold. And a whole bunch of German scrap metal shaped like 924's. Old enough to know better, and stupid enough to do it anyway! |
Let the rear suspension hang at full droop, but support the contol arm with a jack before removing the lower bolt. If you don't support the arm, it will can damage the threads when you remove/install the bolt.
The shocks limit the downward movement of the arm, so the arm will want to droop a little more when you remove the bolt.
Jeff 78 911SC, Silver/Black, H4's, Recaros, 964 Cams, Custom Exhaust, 16" 930 Fuchs. Lowered & Loud
Thanks Jeff...and Wolf. So it is as easy as it seems, great. Only wish the front struts were that easy. Those come next!
