Dan in Pasadena's Avatar
About to Install Rear Koni's - Advice!
I am assuming this will be very straight forward, but maybe I am wrong.
Does anyone know of a location for a quick tutorial with pictures for installing rears on a stock '87 NA? I searched but found nothing.
I had assumed I just jack it, off with the old - on with the new...but do I need to do anything with the springs? Compress them? Other? Please advise. Pix would be great if you have them. Thanks, Dan
Dan in Pasadena
'76 911S Sahara Beige/Cork
Old 01-22-2005, 05:20 PM
Wolf1's Avatar
Off with the old, on with the new. Pretty straight forward.
75 914 - Undecided.
80 931 - Gone, but not forgotten.
72 914 - old toy- sold.
And a whole bunch of German scrap metal shaped like 924's.
Old enough to know better, and stupid enough to do it anyway!
Old 01-22-2005, 05:24 PM
sayporsha's Avatar
Let the rear suspension hang at full droop, but support the contol arm with a jack before removing the lower bolt. If you don't support the arm, it will can damage the threads when you remove/install the bolt.
The shocks limit the downward movement of the arm, so the arm will want to droop a little more when you remove the bolt.
Jeff
78 911SC, Silver/Black, H4's, Recaros, 964 Cams, Custom Exhaust, 16" 930 Fuchs. Lowered & Loud
Old 01-22-2005, 05:37 PM
Thanks Jeff...and Wolf. So it is as easy as it seems, great. Only wish the front struts were that easy. Those come next!
Dan in Pasadena
Old 01-23-2005, 06:42 AM
