Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 924/944/968 Technical Forum
kgelles's Avatar
Question Replacing water pump and timing belts
I am about to change the belts and replace the pump on my 1985.5 944 NA. The belts only have 25,000 miles on them but they have not been changed in five years as the PO did not drive the car more than 5,000/year. More importantly I am almost positive the water pump is leaking coolant. I loose coolant mostly when I am driving. I replaced the oil cooler seals and still have a leak. I checked the compression and all was fine. The pump is a rebuilt turbo-style with only 25,000 miles on it. The leak comes from behind the timing belt cover (it is hard to pinpoint because of this) and appears to originate more towards the passenger compartment side of the pump. I guess it could be a waterpump gasket but I am going to replace the pump since I will have to work my way to it anyway. The only other possibilty I can think of that would cause the leak would be the head gasket altough I am sure the leak is only external. What do you guys think?
1985.5 944 NA
Old 01-23-2005, 10:25 AM
Send a message via AIM to AznDrgn
pressurize the coolant system and see where it blows out of.
'91 Jeep Cherokee 4.0L HO - Daily driver
'83 Callaway 944 2.5L turbo - Soon to be daily driver
'83 Porsche 944 NA - sold
'78 Porsche 924 NA- RIP
'89 Porsche 944 S2 - Parted
Looking for a nice 944S for a daily driver.
Old 01-23-2005, 12:34 PM
jm951's Avatar
Mileage and age are very important in belt change intervals. The leak could be coming through the weep hole in the bottom of the waterpump shaft housing. Change out the seals and rollers while you're in there.
86 951- again on the road, but needing some more TLC
82 931- again among the rolling
"If yer paint aint chipped, you aint passin nobody."
Old 01-23-2005, 12:44 PM
kgelles's Avatar
The seals were changed at the last belt change. Being five years old should they be ok? (If there are no visible leaks when I take off the rear timing cover).
1985.5 944 NA
Old 01-23-2005, 02:33 PM
SoCal Driver's Avatar
Cut the rear cover in half and you will not have to take any balance shaft or crank pullies off.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-23-2005, 06:15 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
