Porsche Crest Leaky Transmission
My manual transmission on my 86 seems to have a slow leak. I'm wondering where is this leak coming from and how to fix it. Also every time I shift into 4th gear I seem to be grinding the gear. The first three gears and fifth are perfect but going into fourth is a problem. Should I pick up a used transmission on ebay or try to fix this one?
keep your stick on the ice.....
86 944na
burgundy/burgundy
Old 01-29-2005, 12:01 PM
Mein Gott!
Panzer909's Avatar
Try spraying the tranny box down with degreaser and clean that sum***** down. This will make it easier to find the leak - its most likely a seal. Then decide if its easy or difficult to fix..........
Johnny
1987 944S
1984 944 (R.I.P.)
1972 Triumph TR6 - 100% trouble free between breakdowns
2003 BMW 325xi
Old 01-29-2005, 04:50 PM
SoCal Driver's Avatar
The seals around the stub shafts. You could have loose and worn shifting linkage pivots/bearings.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-29-2005, 04:53 PM
fast924S's Avatar
Send a message via AIM to fast924S
You might have bad 3-4 syncros
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 01-30-2005, 11:33 AM
Thanks for the tip.....I'll try the degreaser on the trans and see where it is leaking. Is the stub shaft seal easy to replace? How about the syncro's easy or hard to replace?
86 944na
burgundy/burgundy
Old 01-31-2005, 03:31 PM
jm951's Avatar
The stub axle seals are very easy to replace, the syncros are a whole 'nuther matter. You won't know anything until you clean that puppy up.
86 951- again on the road, but needing some more TLC
82 931- again among the rolling
"If yer paint aint chipped, you aint passin nobody."
Old 01-31-2005, 04:18 PM
If I am leaking oil would this explain why only the 4th gear is grinding?
I guess I'll be degreaseing the transmission this weekend.......
86 944na
burgundy/burgundy
Old 02-01-2005, 07:57 PM
