KOG KOG is offline
Aluminum Trailing Arms
What years did the 944 Turbo have rear aluminum trailing arms?
Old 02-09-2005, 08:10 AM
All 944 Turbo models have alu trailing arms.
The alu arm was introduced for the 1985/2 (late dash) 944. It was changed slightly in designed for the 1987 model year due to ABS and continued until the end of 968 production in 1995.
All 924S models also have the alu arm.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 02-09-2005, 08:23 AM
KOG KOG is offline
Does the difference between the '86 Turbo trailing arms and '87 and later trailing arms change what drive shafts you can use?
Old 02-09-2005, 10:42 AM
According to our suppliers, 944 332 038 01 will fit 86-91 MY or the later typpe 951 332 038 02 will fit from 87 on. The difference I believe is the later part uses different CV joints where the early cars used CVs off VW models. Depends on what you are trying to do.
Old 02-09-2005, 01:47 PM
KOG KOG is offline
Are the axle lengths, and transmission drive flange size (bolt pattern) the same between the two part numbers?
Old 02-10-2005, 11:27 AM
