Mike the mechanic's Avatar
S2 camshaft chain HELP
Hey guys, I am in the process of installing a new hydraulic camshaft tensioner and chain on a 1989 S2. The new chain, part number 944 105 501 01, seems to be too long. There is alot of slack once installed. Unfortunately, I do not have the old chain to compare. The new chain has 23 links. Does anyone know how many links the chain is supposed to have?
It doesnt seem like the tensioner can take up all the slack.
Can anyone help??!
Mike
03 996tt w/efr7163
89 Carerra 3.6
Old 07-03-2005, 09:22 PM
aribop's Avatar
23 links sounds right. The number of links between the markings on the cams is 7 outer links. The chain tensioner will take up the slack.
'95 993 Monster in the making
'89 S2/Turbo aluminum grill monster: terrorizing another state
Old 07-03-2005, 09:39 PM
chain
Mike, this is a pic of a timing chain that i've bought to fit to my 944s2 cab when i have the belts checked - it's the same part number and has the following info printed on the wrapper - "Bilstein Steuerkette 458 42 gld. 944 105 501 01 Art-Nr. 09424".
I can only count 21 links though - hope the pic helps.
1989 guardsred 944s2 cabriolet,
1983 metallic claret 924 lux (sold)
Old 07-04-2005, 02:11 AM
Hey guys, thanks for the help. The initial chain I received had 23 links, so I re-ordered, and recieved one with 21 links. Both were the same part #, same package, I guess it was a packaging errot! Phew!
Thanks!
Mike
Mike
03 996tt w/efr7163
89 Carerra 3.6
Old 07-04-2005, 08:30 PM
The 968 uses a longer chain. I'm not sure how many links though. Probably the same manufacturer. Could have been a packaging mix-up.
Mike
'92 968
'01 VW Jetta TDi
Old 07-05-2005, 06:01 AM
could have caused an expensive mix up!
Old 07-05-2005, 07:53 AM
