Condensation in Gauges
Hey guys, I was just getting some fast food and within the 15 min trip the clear covers for the oil pressure gauge and the left cluster (with the engine temp and gas gauge) developed some serious whitish condensation inside them, almost to the point where I can't read it. Has anyone ever experienced this or knows where it is coming from?
Thanks,
Nate
'84 944, '05 GTO
Old 02-14-2005, 11:08 AM
fast924S's Avatar
Send a message via AIM to fast924S
Yea, this will happen in my 924S if I let it site for days, then when I start it I get it in my far left gauge pod, I believe there is a O-ring type seal or something that is bad that is letting moisture into the gauge, then when it heats up blam steam on the gauge
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 02-15-2005, 03:03 PM
mitsumark's Avatar
Open your hood and check along the firewall..You could have water finding its way behind the dash..If this is the case,it should get worse as the circuits heat up or when using the heat..Another possibility could be a leaky heater core..I hope not for your sake..
84 Guards Red 944
88 Conquest TSI
98 Pontiac GTP
Old 02-15-2005, 05:27 PM
