Occasional Valve Tick On Startup
Every now and then I get a little valve train tap when I first start the engine. It immediately goes away as soon as the oil pressure gauge moves upward. Such noises never occur when the engine has been running.
I think oil is draining off of something in the valve gear. Is this a problem? It began doing this occasionally a little over 1.5 years ago. I used Mobil 1 15w-50 in the car and change oil every other track event meaning every other month as I do a track event every month.
Engine has 153K on it and has been used as a semi-daily driver and track vehicle since 1996. Belts are changed every year. It runs well. There are no metal chips or anything link that on the oil drain plug. There is, however, a small bit of paste sticking to it.
The amount of paste has decreased considerably since I added a second oil cooler.
Anyway, should I just continue along my merry way or repalce some parts?
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 02-25-2005, 08:12 AM
Parrothead member
VINMAN's Avatar
Sounds like your lifters are bleeding down , not something to be overly concerned about. If it was constant ticking youd have a problem.
What does your o/p guage sit at normaly
Vinny
Old 02-25-2005, 08:18 AM
Oil pressure gauge (assuming it is correct) reads 5 bars at above idle speed. When hot it reads 3.5 bars at idle but immediately jumps back to 5 when you tap the gas.
Thanks for input.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 02-25-2005, 08:42 AM
ae1969's Avatar
Send a message via ICQ to ae1969
If its happening overnight you more than likely have a bad lifter.
Its a nuisance at this point. I would wait for the next servicing before digging in. (Preferrably next head gasket)
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 02-25-2005, 08:51 AM
Yes, it takes a number of hours for it to happen and then it doesn't always happen.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 02-25-2005, 08:56 AM
Mein Gott!
Panzer909's Avatar
Mine has been doing this for about the last 4+ years - I've never had a problem. Keep going about your business.
Johnny
1987 944S
1984 944 (R.I.P.)
1972 Triumph TR6 - 100% trouble free between breakdowns
2003 BMW 325xi
Old 02-25-2005, 10:54 AM
OK, just wanted to check with you guys. I'll leave things as they are.
Thanks.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 02-25-2005, 12:08 PM
position of a cam lobe may effect whether it happens or not
Tom
Early '85 944
Old 02-25-2005, 03:08 PM
