-   -   Spring question (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/208217-spring-question.html)
mitsumark 02-25-2005 05:25 AM
Spring question
Will springs off of an 86 Turbo go on a early 944 without drastic modification??Saw a set of H&R's I want to bid on but they are off of an 86 951...Thanx..
DannoXYZ 02-25-2005 09:06 AM
Yeah, they'll fit. But they'll raise your front-end about 1".
ae1969 02-25-2005 09:43 AM
They will swap right in.
What is the spec on those springs you are looking at? To be honest 200 is the mininum I would waste my time and effort swapping into any 944. YOu are not going to feel any difference from swapping stock springs around from the other respective models.
The turbo springs are actually 1/2 inch longer to accomodate a little more weight. The ride height will more than likely remain the same with a turbo spring swap and I would imagine the H/R being the same for comparisons sake.
944/924S/944S/951 non-M030: 21.8 N/mm (125 lb/in)
944 M030 to 1986, 944S2 non M030: 24 N/mm (137 lb/in)
944/924S/944S2/951 M030 (1987 and later): 28 N/mm (160 lb/in)
DannoXYZ 02-25-2005 09:59 AM
Whoops, I mis-read the original message. Are you looking at stock Turbo springs or H&R springs for your car? If they are stock Turbo springs, you will raise the front end due to the longer spring and higher rate. If they are H&R springs which lower the Turbo by 1", then you will end up at stock ride-height on a 944NA.
mitsumark 02-25-2005 01:25 PM
They are H&R's off an 86 Turbo..I was buying them to more less lower my front end..If they will not lower the front,,I'll pass on them..Does anyone know of a company that makes them for the early's??I looked and only found Eibach,,but it turns out they are discontinued...
Rmills944 02-25-2005 02:33 PM
Koni, Bilstein (I think), Weltmeister. You will probably want new struts while you're in there.
my924gtc 02-25-2005 02:47 PM
I recommend this Ground Control kit. They use Eibach springs and you can set your hieght as you see fit.
