iobound's Avatar
Send a message via AIM to iobound
Help with Blower problem
My blower works on position 4 but nothing happens on positions 1 through 3. Any ideas? I have a 88 944 NA.
RPM also stands for Redhat Package Manager
16 year PCA Member
NASA Member
1988 944 NA w/4valve S motor (Daily Driver)
1992 965 Coupe 3.4 Liter, webers, GE60 (Garage Queen)
1998 Volvo V70 Wagon
2002 Barbie Electric Kids Jeep
Old 03-15-2005, 02:10 PM
Cars & Coffee Killer
legion's Avatar
Bad blower switch?
5 liters of VVT fury now
-Chris
Old 03-15-2005, 02:13 PM
iobound's Avatar
Could be! The motor works so I figured it had to be the switch. But does that mean I have to replace the entire climate control system? That would be pricy.
16 year PCA Member
NASA Member
Old 03-15-2005, 02:17 PM
SoCal Driver's Avatar
Resistor bridge on blower. Need to pop it off and clean it. Has safetys that corrode.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 03-15-2005, 10:53 PM
bearone2's Avatar
what's the resistor bridge look like? could you put up a pic please.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 03-15-2005, 11:09 PM
iobound's Avatar
BIG thanks to all. I will check the resistor bridge tonight.
16 year PCA Member
NASA Member
Old 03-16-2005, 04:00 AM
No pic, but on the early it's the cylindrical thing mounted directly in front of the blower motor (under the squirrel cage). Can't miss it.
1983 944 with S2 motor, trans, suspension and exterior -- crunched parts car
1987 944 -- soon to be 1987 944S2
Old 03-16-2005, 07:07 PM
On the later it's in about the same place but under a plastic cover. Think it's vented on the sides. Once you get to it you can use a test light to check that the switch in the dash is getting voltage to it.
Old 03-16-2005, 07:29 PM
