callmethewander's Avatar
3100-3200 rpm rumble
i get like a rumble or a rattle at about 3100 rpm in my '88S, under acceleration, any ideas, also where can i get those plastic arms that hold the glovebox door from falling all the way down, like mine does now? i don't see them at pelican
1991 cabriolet (sold)
1989 S2
1988 S
1987 944 n/a (sold)
1987 944 factory yellow (junked )
Old 03-26-2007, 04:56 PM
That Guy
Techno Duck's Avatar
Balance shafts out of phase?
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 03-26-2007, 05:08 PM
Paragon Products sells metal arms for the glovebox. Very nice and easy to install.
Old 03-26-2007, 05:33 PM
winter-hater club member
nynor's Avatar
944online has them as well. if you search my posts, i have installed them.
"COOL PRIUS!" - Nobody Ever
Old 03-27-2007, 06:15 AM
Proprietoristicly Refined
John_AZ's Avatar
I have read that the rumble may be the onset of clutch trouble and/or vibration. I had a rattle for years until I replaced my thermostat and found it did not have the wraparound rubber gasket.
John_AZ
1988 924S
1987 924S
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 03-27-2007, 07:07 AM
John_AZ's Avatar
I found the web site:[url]http://www.connactivity.com/~kgross/FAQ/944faq09.html
This may not apply to you. I am not familiar with 944S clutch disk. Is it original rubber? Good luck
John_AZ
Old 03-27-2007, 10:11 AM
ERAU944's Avatar
Send a message via AIM to ERAU944
i'm going to say it's a toss-up between these two:
the (rubber center, if so equipped) clutch took a dive
the balance shafts are out of alignment
if your car ran fine before, check your clutch. my clutch went and i drove it for probably close to 1k miles before i realized that that vibration was not due to the b/s's, but due to different BS altogether.
Mike - CFI, A&P Mechanic w/ I.A., Aztec driver at Island Tyme
'88 951S - zermatt silber/black - staying stock. purchased in 11-2006
'84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001
2021 Tesla Y - to get me to work
Old 03-27-2007, 02:33 PM
Don't forget to check the fluid filled motor mounts, they dry up in storage and go bad, when one does you get shaking as a result.
AJF
1998 Glacier White Boxster
1971 Fiat 124 Spyder
1999 Mercury Mountaineer
Old 03-27-2007, 03:15 PM
hmm,thank-you all, the car idles smooth w/ no vibration i had bad mounts in my '87 and it vibrated a lot so i don't think thats it, i'll check 'em when i get under there tho. i changed my transaxle fluid today whatta PITA the old stuff didn't look bad but i still get that rattling at idle with the clutch engaged whenshe's warm, i wonder if that related to the rumble under acceleration, i sorta don't think so.balance shaft seems possible, i hope it's not the clutch, i'm just approaching 80,000 on the odo.
1989 S2
1988 S
1987 944 n/a (sold)
Old 03-27-2007, 07:29 PM
ERAU944's Avatar
the rattling (both my cars have it, the 951 not as bad as the 944) i believe is caused by the throw-out bearing. it stopped for a couple weeks in the 944 after i changed the clutch (and pressure plate and bearings), then it started up again. if the clutch is rubber centered, mileage really isn't a consideration - rubber deteriorates no matter what. just crawl under the car and have a look-see at the clutch inspection hole. if you find little chunks of rubber(and your clutch is rubber centered) then you know what you're going to have to do (and you can replace that rattling bearing as well). just a side note, when my clutch went, i noticed that i had a LOT and i do mean a heck of a lot of drivetrain lash. i thought that my ring and pinion were on the way out, but then i noticed the vibration, and put 2 and 2 together.
ok, ramble over, have a good look at that clutch...
Old 03-28-2007, 05:38 AM
StoneGrey's Avatar
I had the same rpm vibration when my S2's rubber clutch went. Almost replaced the CV joints....
Daily driver
89 944S2 Coupe
PowerMax Chip
Stone Grey
Aero Mirrors
Full engine rebuild July 2007
Old 03-28-2007, 09:24 AM
wow, they still used the rubber clutches in the late models? thx.
1989 S2
1988 S
1987 944 n/a (sold)
Old 03-28-2007, 01:18 PM
rberry951's Avatar
None of the turbos have rubber puck clutch disks. I checked into this when my first clutch went, in first car, only replaced it once. But have new car, and it needs one on the onset. Takes about 1/2 on the pedal to disengage it.
EDIT: I just looked and saw that you're speaking about your 88S, if not a turbo S the above isn't fully qualified because I have never owned an S and have no idea if it has a puck or not. But the troubleshooting below still applies either way.
Anyway, you want to do some tests. Sitting still, run it in neutral with clutch all the way in, vary rpm including your vibration range. When you find the spot in the rpm that it does it sitting still let the clutch out. What your testing here is
1) If it does it at all it is engine or clutch. If not, drivetrain troubleshooting.
2) If it stops with clutch depressed, it's not the engine or engine mounts. If it does still vibrate while disengaged, balance shaft could be loose and/or motor mounts are shot, or the clutch, including thorwout bearing, fork, etc. But, motormounts also come into play in the drivetrain troubleshooting part even if it does not do it sitting still.
3) If it does not do it at all sitting still you're looking at motor mounts, torque tube bearings, CVs, tranny mount, and basically anything that moves south of the bell housing.
My process was vibration, slipping, new clutch. New clutch killed engine mounts, vibration came back. New engine mounts got rid of vibration. But then I spun out at Watkins Glen, flatspotted all four tires, warped all rotors, and busted one ball joint that failed later at an inopportune moment. I'm not going to get into what happened after that...
Thing is, it may also be as simple as a tire out of balance, or an out of round tire. Just have them balanced first and watch them do it, look for true roundness and a true rim, as in no wobble. If they're balanced true and your vibration is still there, see above.
Regards,
Russell
Russell Berry
1986 911 Carrera Targa Widebody/Slantnose
Old 03-28-2007, 07:34 PM
My drivetrain also vibrates around 3000-3100 rpm, I've got a spring-hub clutch, and I'm sure my balance shafts are on time, so I'm going to replace my motor mounts. My passenger side mount has been updated, but is collapsed, and the drivers is factory and far below the limit. Hopefully that fixes it.
-Gabe
-black 1988 924s, 944 turbo sway bars, LSD, gunmetal phone dials-- SOLD to some people who cannibalized her
-1987 MR2
---ONLINE REP FOR RADMACHER PORSCHE SERVICE IN TUCSON---
Old 03-28-2007, 08:59 PM
ok, thx a lot. it's not a turbo S, just the 16 valve. i'll follow those diagnostic procedures.
1989 S2
1988 S
1987 944 n/a (sold)
Old 03-29-2007, 12:38 PM
The 3kish vibration is mostly associated with balance shaft problems. Often the lower balance shaft pulley is installed in the wrong keyslot. The pulleys have 2 keyslots, one for the upper pulley and the other for the lower. Putting the lower pulley on in the wronk keyslot puts the lower balance shaft out of phase even if the pulley notches all line up correctly.
Old 03-29-2007, 05:58 PM
hmmm, thx
1989 S2
1988 S
1987 944 n/a (sold)
Old 03-29-2007, 06:52 PM
