951 question
I just need more power and want a newer car. With everything working AC nice interior ext!!!
How much do i have to spend to get a 951 that needs nothing. I know this may sound crazy but i would much rather pay more for one that is perfect.
Musts
New clutch
less than 100k
new water pump timing belt
new wastegate
rebuilt turbo
working ac
no leaks
new motor mounts
Essentially everything that I have replaced on my NA
it is just so easy to spend thousands on repairs i would rather just buy one that is perfect
83 944na
Old 04-24-2005, 09:22 PM
That Guy
Techno Duck's Avatar
It may be tough finding a car with all the criteria, but you should be able to find something with most of it. I would say for a car you are describing expect to pay in the $9000+ range.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 04-24-2005, 09:59 PM
murn's Avatar
In the April edition of Excellence magazine the latest Porsche market update was for the 924, 944, 968 series.
Here are the average prices for excellent cars (they also sitegood and poor examples):
1986 - $9700
1987 - $10900
1988 - $11150
1988 Turbo S - $12638
1989 - $13813
Old 04-28-2005, 08:12 PM
seaboltman's Avatar
your requirements are too... exclusive? if you can find something that comes close, just pay to have it done as soon as you get it. You will have a HARD time (if not impossible) getting something that qualifies for all those.
1987 944 - Wrecked turned parts car
1986 944 - Awesome Auto
Old 04-28-2005, 08:28 PM
murn's Avatar
Also check the controls arms. The turbos have the aluminum control arms with irreplacable ball joints. Oh and the steering rack too. I had the unfortunate double wammy on that combination. Rack leaked and ruined ball joint. Not sure what the parts cost is US dollars today but control arms are $700 CDN each and so was a new steering rack.
I switched by arms to steel ones with replaceable ball joints from Markus Blazak. Two arms for the price of one.
Old 04-28-2005, 09:25 PM
schmedes1's Avatar
Murn, what are the April Excellence prices for 1988 (Turbo S) and 1989 T cars in "good" condition?
Old 04-30-2005, 07:39 PM
fast924S's Avatar
Send a message via AIM to fast924S
WOw, her in CT I see 951 for 10,000 to 15,000 seems kinda high
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 05-01-2005, 12:59 AM
murn's Avatar
For Good condition:
1988 Turbo S: $9440
1989 Turbo: $10318
1986 944T (for sale)
2003 Boxster S
Old 05-01-2005, 10:28 AM
schmedes1's Avatar
Thanks Murn! Paid right on line and not the gotta have it prices.
Old 05-01-2005, 03:12 PM
1.2gees's Avatar
Send a message via AIM to 1.2gees
"New clutch
less than 100k
new wastegate
rebuilt turbo
working ac
no leaks
new motor mounts"
Well you're not likely to find one with all of those parts replaced, especially the wastegate and rebuilt turbo. I've owned a 944 turbo that didn't use oil, didn't smoke and was on the factory un-touched turbocharger at 140+k. Motor mounts are also trivial.
I would budget around $10k and look for a car that was well maintained, and felt tight. Go drive several examples before you buy one.
Ahmet
Cheers!
Old 05-01-2005, 05:20 PM
Custom User Title
rammstein's Avatar
Bula- my car for sale hits a lot of your criteria. The A/C is bunk, used to work and then stopped. I've been on a crusade for years irradicating leaks. Clutch is relatively new (4 years or so), belts all done. New leather, new paint. Looks gorgeous. Check out my maintenance spreadsheet on my website:
951 for sale
You're only in NH, why not come and drive it? Get it inspected! Run a carfax!
Old 05-02-2005, 07:36 AM
Most every used 951 is going to need some work, unfortunately there's a bit of luck involved. Some higher mileage examples have a lot of trouble free miles in them, but a 70k mileage example might have a #2 bearing that's almost ready to go.
Even with a ppi you're going to have some surprises. Be sure to get a ppi from a very well chosen mechanic, the ppi is only as good as the mechanic who's doing it.
Old 05-02-2005, 04:18 PM
1.2gees's Avatar
rammstein, there are broken links on your "for sale" web page.
Ahmet
Cheers!
Old 05-03-2005, 02:16 AM
I've been working on 944s since their inception. I'm not saying that 944 engines don't fail but the usual reasons for rod bearing failure are either: owner runs engine low on oil (most common), car raced or tracked with low oil level or extensive racing.
There are other reasons, including modifications that don't work, excessive boost or just "it happens" syndrome etc, etc..
Apart from that I wouldn't be concerned with mileage, whether for a turbo or NA version.
If this rod bearing failure problem was widespread, there would be more posts on the board and we would have a bunch of them in the shop.
And I would be lying on the beach in Hawaii relaxing because of all the money we'd made rebuilding the engines.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 05-03-2005, 08:55 AM
vott does ziss do?
ronin's Avatar
I knew we were doing something wrong!
Old 05-03-2005, 08:57 AM
Custom User Title
rammstein's Avatar
Dammit- what links aren't working for you guys? Some people say the videos don't work, others say they do! Hopefully the most important link ($ spent) is working.
Old 05-03-2005, 03:32 PM
