strath44's Avatar
Arghh new door alignment out!
I had set aside an hour or so to put my replacement door on tonight. Anyway after at least 2 hours of wrestling it won't line up (even with my father helping). When the bolts are slack and I lift it up it will close but when I tighten them it sits at least 1/3 of an inch to low at the lock end.
The car had taken a light hit to the old door but it still closed (I only replaced it due to damage around the handle and rust). So any thoughts, can I put washers between the door hinge plates to back it out or any better tips on hanging the door?
At worst A-pillar may be slightly out can this be fixed or will it need a new one welded in - there is very little visible damage to it?? Wondered about putting the alloy jack in the door frame with 2x4's and trying to back the A-pillar out slightly but worried it might go wrong?? If I take it to my local bodyshop (they are pretty good) will they be able to fit it properly at not to much cost?? any help appreciated!
1991 944 Turbo
2012 VW Passat
2008 Mini Cooper
Old 03-23-2005, 01:26 PM
strath44's Avatar
Help anyone any thoughts on something I can try, the cars getting mot'd (roadworthyness test) on Tue and don't want to put the old door back on (especially as I've stripped it of all it mechanisms)!
1991 944 Turbo
2012 VW Passat
2008 Mini Cooper
Old 03-23-2005, 11:03 PM
Try this:
1) Open door wide.
2) Place a piece of lumber (approx. 2 inch by 4 inch across door sill)
3) Close door as much as you can.
4) Use lumber to leverage door upwards.
5) Remove lumber.
6) Test door fit.
Repeat as necessary.
I know that this seems like blasphemy, but it works...
gb
Good luck, George Beuselinck
www.944ecology.com
Porsche Deconstructor (tm)
We buy 944s and sell 944 parts (845-379-1944)
We rebuild torque tubes and instrument clusters for 944/968/928
Old 03-26-2005, 04:29 AM
strath44's Avatar
cheers mate, will try it on sunday. If it doesn't work I'm going to take the car to a bodyshop on Tue for them to have a look and if necessary put it on a jig and give it a pull!
1991 944 Turbo
2012 VW Passat
2008 Mini Cooper
Old 03-26-2005, 01:57 PM
