seaboltman's Avatar
Axle Interchangability
Passenger side rear axle is broken. Its a 86 automatic. My parts car is a 87 Manual. will the axles be able to be swapped out or and I looking like I need to buy a new one?
1987 944 - Wrecked turned parts car
1986 944 - Awesome Auto
Old 03-25-2005, 06:51 AM
SoCal Driver's Avatar
There are manual axles for steel trailing arms, manual axles for aluminum trailing arms, auto axles for steel trailing arms and auto axles for aluminum trailing arms.
Then there are the 87-88 turbo axles.
seven different part numbers.
Auto axles are different lengths per side.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 03-25-2005, 07:09 AM
seaboltman's Avatar
how depressing. Now I guess i have a real reason to do my auto-> manual swap.
Old 03-25-2005, 07:33 AM
The CV joints are the same. Depends on what you actually need.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 03-25-2005, 07:37 AM
seaboltman's Avatar
axle is cracked in half. Need the entire thing.
Old 03-25-2005, 07:59 AM
Expect you could find one easily at a junk yard, or try on the parts post.
Old 03-25-2005, 09:15 AM
seaboltman's Avatar
nah, it gives me an excuse to do the swap. 5 speed here i come.
Old 03-25-2005, 10:30 AM
Zero10's Avatar
Send a message via ICQ to Zero10
I thought all of the N/A 5 speed CV axles were the same.
Although, I never tried to swap them around.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 03-25-2005, 11:21 AM
The later turbo axles are a replacement for the later manual axles.
Old 03-25-2005, 02:52 PM
