fans
86 944 non turbo. radiator fans continue to run and drag battery down. What I am looking for : fan motor itself, sensor, wiring etc.
newby
Old 03-26-2005, 04:06 PM
SoCal Driver's Avatar
Thermal switch on the radiator then the large silver relay at the back of the fuse/relay box. Better hope it's the $15 switch and not the $150 relay.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 03-26-2005, 04:43 PM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson Send a message via AIM to bryanthompson Send a message via Yahoo to bryanthompson
^---- what he said
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
entertaining the idea
UconnTim97's Avatar
Trust Socal....
There are some who call me... 'Tim'.
a well set-up 1983 Guards Red 944
Old 03-26-2005, 09:49 PM
fans
i am hoping for the 15 buck switch.
thanks for the heads up
Old 03-27-2005, 02:09 PM
With the engine cold; if you can get to the plug that's on the switch (top rear drivers side of the radiator) and pull it off while the fans are running you can figure it's the switch if the fans stop. If the fans don't run when you plug the switch back in then start thinking relay.
Old 03-27-2005, 03:34 PM
