coltabsh's Avatar
Post no spark out of cap
I was having problems with no spark at the coil and have found that problem it was the speed and reference sensor the old owner of the car decided to cut a wire on the speed sensor… well now my problem is I have no spark out of the cap.. I have cleaned out the cap and checked everything. The belts do move so its not that I do have spark going into the cap but nothing out of it???
Is it the cap or rotor??
Where is there a cheaper one I am kind of strapped for cash so I need to get one somewhat cheap?
Thanks for any help
Shane
86 fiero 2m4 gold
86 fiero 2m6 silver
83 944 n/a
Old 03-28-2005, 01:39 PM
SoCal Driver's Avatar
Check the sping loaded center contact and the rotor from the center to the tip. Think there is a resistor in it. Then maybe not.
There is a chance that the HV cable between the coil and the cap has been caught and damaged by the arm on the head light linkage. Pulls the wires out of the connectors inside of the weather boots.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 03-28-2005, 02:29 PM
check the screw that holds the rotor to the shaft too
Tom
Early '85 944
Old 03-28-2005, 02:46 PM
Do you have spark out of the coil? It's just not getting out of the cap?
Yeah, most likely what Tom said, one of the two bolts holding the rotor on may not be installed. If your rotor points in the wrong direction when the spark fires, it's not gonna make it out of the distributor cap...
Old 03-28-2005, 10:03 PM
