-   -   Pitch Circle Diameter of Wheel Lugs (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/213464-pitch-circle-diameter-wheel-lugs.html)
Paul Glasson 03-29-2005 12:09 AM
Pitch Circle Diameter of Wheel Studs
Just to confirm what I can gather from a search I did on Wheels. mlue (17/2/05) speaks about standard 944 wheels having a 5 x 130 bolt circle, and iceshark (19/2/05) a 5 x 130mm stud spacing.
I take it that is the same as what I would refer to as the Pitch Circle Diameter of the 5 wheel studs?
I can get 15" alloy wheels that are made locally here where they will machine the stud holes to the PCD I require.
What else beside offset should I be careful of when purchasing new wheels?
I am keeping to the 15" 215/60 Bridgestone Potenza SO3 tyres I have as it is too expensive to replace all 4 tyres at same time as wheels.
thanks
fast924S 03-29-2005 02:49 PM
I would just make sure they are made well, I have seen some wheels crack, Also rim weights if they are heavier then it could hurt performance
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
