what size allen wrench trans
what size allen wrench do i need to buy to remove the drain & fill plugs on my trans axle.
83 944 5sp thanks! |
17mm
Get one for a socket wrench, that will fit a torque wrench if you can. |
I think the trans oil drain plug torque is 17 ft lb.
thanks! done.
And, of course, remove the fill plug first, so that you don't end up with a dry trans if you can't remove the fill plug...
gb |
I took a old spare wheel bolt (17mm) from the 924 and welded it into a cheap 1/2 drive socket.
I WOULD HAVE PREFERRED THAT, S&K HIT ME UP FR$22 FOR THE 1\2" DR SOCKET
| All times are GMT -8. The time now is 03:14 AM. |
