max29a's Avatar
just an update on no start
Hello,
Still trying to track down what was intermittent engine power loss, and is now a no start. Engine cranks fine but never fires up. I have replaced fuel filter, checked TPS, checked that fuel comes out the end of the rail, and I just got done checking DME itself for bad solder joints.
Next up I plan to check spark, check DME relay again. This is the 3rd relay that has been stuck in the car, but I guess its worth cracking it open just to make sure they werent all bad or something.
Just a note: the car sat for a month, and when I came back to it the battery was totally dead. Is this normal? Does this point to any other things I should check?
I am a newbie, what do I do to check grounds?
1985.5 944 NA - 270k miles!
2001 suzuki sv650 - 37k miles
oil change done at 270k
timing belt done at 240k
Old 03-30-2005, 08:13 AM
A new/good battery should be able to sit in the car for a month, and still crank it...something is draining the battery...radio, light, alarm, etc.
Poor/bad grounds are hard to find. Start with the ground for the DME and main fuse panels.
Intermettant power loss, and now no start? hmmm...check the set-screw in the rotor button.
good luck
JM
Old 03-30-2005, 10:18 AM
SoCal Driver's Avatar
Follow the ground cable from the battery and clean every contact point. Especially on the block to chassis.
Do you have power to the coil with the ingition turned on?
Do you have power to the injectors with the ignition turned on?
Can you hear the fuel pump running for a second after you stop cranking?
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 03-30-2005, 01:14 PM
Sounds a little like when my fuel pressure regulator went out. Unplug one of the injectors and see if she fires. If she does bad FPR. If not dunno.
88 928 S4 Black, Black and Grey Interior
Alpine head unit & amp, Bazooka Tube, Viper 5704 Smart Start GPS tracking, Devek Headers, Flowmaster 40 3" with Resonator, Auto Authority chips. Custom Luggage Cover.
Traded - 86 944 Turbo Guards Red. RIP - 85.5 944 Guards Red
Old 03-30-2005, 09:10 PM
Hmm, battery being dead after a month is normal. Typically, you want to keep it on a trickle charger or drive it once a week to keep the battery charged.
As for the no-start, do you have spark? That is, pull the cable out of the center of the distributor, stick a spark-plug in it and rest on the distributor housing. Crank, do you have spark?
Fuel is a little tougher to test. Pull fuel-rail, put little clear plastic cups under the injectors and crank. Do you have fuel-squirting into the cups? Make sure you put the spark-plug wire back in so you don't ignite yourself on fire. This test is the ONLY definitive procedure for fuel. You may have power to the fuel-pump and it dumps fuel out the end of the rail, but if the FPR or dampener is clogged or if you don't have power to the injectors, no fuel will enter the engine.
Old 03-30-2005, 09:25 PM
max29a's Avatar
Thanks for all the suggestions. I cracked open the DME relay to double check it this morning and it looks brand new. About a half inch of one of the copper wraps had come off and was being sandwiched in the relay when it was given voltage. I put the copper wire back where it should be but somehow I really doubt that that was the problem.
I have this entire Saturday scheduled for working on the 944 with friends helping so I will definitely try all of your suggestions then and keep you updated.
Old 03-31-2005, 07:35 AM
ae1969's Avatar
Send a message via ICQ to ae1969
Do this...
and this
Report back.........
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 03-31-2005, 10:43 AM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
speed and position sensors.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 03-31-2005, 02:14 PM
Roger Hall's Avatar
Yes
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 03-31-2005, 05:02 PM
max29a's Avatar
SUCCESS!!!
well I reinstalled my DME, DME relay, bought a new battery.
I then went to test the speed and ref sensors and as I grabbed the connector it fell apart. I plugged it back in and the car started right up!
I feel dumb for not checking that sooner, but I know how to do more on my car and then engine bay is a bit cleaner.
Thanks to everyone for the advice.
Old 04-02-2005, 12:06 PM
Where are the speed and just so I know
Old 04-02-2005, 09:22 PM
The speed/ref/ sensor connectors are on a metal bracket at the rear of the engine. They are rectangular in shape. The round O2-sensor connector is on that bracket as well.
Max, gimme a call, I may have some extra 3-pin male & female connectors...
Old 04-04-2005, 04:32 AM
max29a's Avatar
I will give you a call... the plastic housing on both speed and ref sensors are broken where they connect at that bracket. For now I electrical taped them together and removed the bracket and put it in my glove box.
Old 04-04-2005, 07:45 AM
