1987 944 ECU Installation Help
I need assistance on the installation a Motronic ECU into a 1987 Porsche 944 (non-Turbo.) The vehicle has been out of service for a couple years. I went through everything, everything was operational (turning over, spark, fuel injection) but the vehicle would not start. In doing research, it seems a likely cause is the ECU. I just bought a 944.618.121.04, and need the location of the ECU.
1. I know it is on the passenger side. Exactly were? Under the front carpet under the wooden firewall cover?
2. Pictures would be helpful (I know this is a long-shot.)
I could tell you the history of the car, the repair attempts and a very good horror story. I got a bid fed up with it, and mothballed it in the garrage. Now I'm willing to try anything/everything to get it running. I'm hoping it is a simple fix, but if not, any and all help is appreciated.
-Doug
Old 03-30-2005, 04:20 PM
SoCal Driver's Avatar
Detail the tests you've gone through to determine it's the DME/ECU.
Is this a 944S four valve?
You should see voltage at the coil and at the injectors with the key on. If no voltage at the coil it's the ingition switch. If no voltage at the injectors but voltage at the coil, it's the DME/fuel pump relay.
If the above is good but you have no spark at the coil/plugs then it could be the DME or the reference sensor on the back top of the engine.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 03-30-2005, 04:44 PM
Can a early na or turbo cam be used in a late na?
Old 07-11-2018, 03:04 PM
Yes, it can, but it will produce less power.
Good luck, George Beuselinck
www.944ecology.com
Porsche Deconstructor (tm)
We buy 944s and sell 944 parts (845-379-1944)
We rebuild torque tubes and instrument clusters for 944/968/928
Old 07-12-2018, 05:20 AM
to answer the OP
Yes the ECU is under the wood panel on the passenger sidewall. Remove the wood. Unplug the ECU, remove the bracket and ECU. Pretty easy.
I hope that is the real culprit, but that is how to replace the DME (ie. ECU)
Bruce P.
New to me 2011 Cayman Base, LSD, Sport Chrono.
1988 951 totaled and missed
"You're the best I ever had" --JJ Cale
Old 07-12-2018, 05:55 PM
